Salta al contenuto principale
Asus ROG Ally Back Cover Replacement
Cosa ti serve
  1. Asus ROG Ally Back Cover Replacement, Prepare your device for disassembly: passo 1, immagine 1 di 3 Asus ROG Ally Back Cover Replacement, Prepare your device for disassembly: passo 1, immagine 2 di 3 Asus ROG Ally Back Cover Replacement, Prepare your device for disassembly: passo 1, immagine 3 di 3
    • Let your device's battery drain below 25% before starting this repair—a charged lithium‑ion battery may catch fire if damaged.
    • Completely power off your device and unplug all cables.
    • Consider laying your device on a soft cloth to prevent scratching or damaging the screen during your repair.
    Chiedi a FixBot
    Aggiungi Commento
  2. Asus ROG Ally Back Cover Replacement, Unfasten the back cover: passo 2, immagine 1 di 2 Asus ROG Ally Back Cover Replacement, Unfasten the back cover: passo 2, immagine 2 di 2
    Strumento utilizzato in questo passaggio:
    FixMat
    $31.41
    • Use a Phillips #0 screwdriver to remove the five 17.2 mm‑long screws securing the top edge and bottom corners of the back cover.
    • Use a Phillips #0 screwdriver to fully loosen the remaining captive screw at the center of the bottom edge. This should create a small gap between the back cover and chassis.
    • Don't try to remove this screw.
    Chiedi a FixBot
    Aggiungi Commento
  3. Asus ROG Ally Back Cover Replacement, Insert an opening pick: passo 3, immagine 1 di 3 Asus ROG Ally Back Cover Replacement, Insert an opening pick: passo 3, immagine 2 di 3 Asus ROG Ally Back Cover Replacement, Insert an opening pick: passo 3, immagine 3 di 3
    • Insert the flat edge of an opening pick between the bottom edge of the back cover and chassis, near the captive screw.
    • Angle the pick upward and push it under the back cover.
    Chiedi a FixBot
    Aggiungi Commento
  4. Asus ROG Ally Back Cover Replacement, Release the back cover's clips: passo 4, immagine 1 di 3 Asus ROG Ally Back Cover Replacement, Release the back cover's clips: passo 4, immagine 2 di 3 Asus ROG Ally Back Cover Replacement, Release the back cover's clips: passo 4, immagine 3 di 3
    • Plastic clips secure the perimeter of the back cover. You should feel and hear them release during this step.
    • Slide the opening pick along the bottom edge and around the corners of the back cover to release the clips securing it.
    • Keep the pick at an upward angle under the back cover to help release the clips.
    Chiedi a FixBot
    Aggiungi Commento
  5. Asus ROG Ally Back Cover Replacement, Remove the back cover: passo 5, immagine 1 di 3 Asus ROG Ally Back Cover Replacement, Remove the back cover: passo 5, immagine 2 di 3 Asus ROG Ally Back Cover Replacement, Remove the back cover: passo 5, immagine 3 di 3
    • Lift the bottom edge of the back cover off the chassis to release the remaining clips.
    • Remove the back cover.
    • During reassembly, lay the back cover onto your device and firmly push down around the perimeter to engage the clips.
    Chiedi a FixBot
    Aggiungi Commento
  6. Asus ROG Ally Back Cover Replacement, Check your replacement back cover: passo 6, immagine 1 di 2 Asus ROG Ally Back Cover Replacement, Check your replacement back cover: passo 6, immagine 2 di 2
    • Check if your replacement back cover comes with triggers and macro buttons installed.
    • If it doesn't, follow the remaining steps to remove and transfer them.
    Chiedi a FixBot
    Aggiungi Commento
  7. Asus ROG Ally Back Cover Replacement, Unfasten the macro buttons: passo 7, immagine 1 di 2 Asus ROG Ally Back Cover Replacement, Unfasten the macro buttons: passo 7, immagine 2 di 2
    • When removing the screws, be careful not to lose the springs under them. They can easily eject!
    • Use a Phillips #000 screwdriver to remove the 2.9 mm‑long screw securing each macro button (two total).
    Chiedi a FixBot
    Aggiungi Commento
  8. Asus ROG Ally Back Cover Replacement, Remove the springs: passo 8, immagine 1 di 3 Asus ROG Ally Back Cover Replacement, Remove the springs: passo 8, immagine 2 di 3 Asus ROG Ally Back Cover Replacement, Remove the springs: passo 8, immagine 3 di 3
    • Use tweezers or your fingers to remove the springs from their screw posts.
    Chiedi a FixBot
    Aggiungi Commento
  9. Asus ROG Ally Back Cover Replacement, Unclip the macro button: passo 9, immagine 1 di 3 Asus ROG Ally Back Cover Replacement, Unclip the macro button: passo 9, immagine 2 di 3 Asus ROG Ally Back Cover Replacement, Unclip the macro button: passo 9, immagine 3 di 3
    • Two rectangular clips secure the macro buttons to the back cover.
    • Use the flat end of a spudger or your fingers to push in the clips securing one of the macro buttons.
    Chiedi a FixBot
    Aggiungi Commento
  10. Asus ROG Ally Back Cover Replacement, Remove the macro button: passo 10, immagine 1 di 2 Asus ROG Ally Back Cover Replacement, Remove the macro button: passo 10, immagine 2 di 2
    • Remove the macro button.
    Chiedi a FixBot
    Aggiungi Commento
  11. Asus ROG Ally Back Cover Replacement, Remove the other macro button: passo 11, immagine 1 di 2 Asus ROG Ally Back Cover Replacement, Remove the other macro button: passo 11, immagine 2 di 2
    • Repeat the last two steps to unclip and remove the other macro button.
    • During reassembly, firmly push the macro buttons into place to engage their clips. You should feel the clips click as they engage.
    Chiedi a FixBot
    Aggiungi Commento
  12. Asus ROG Ally Back Cover Replacement, Unfasten the triggers: passo 12, immagine 1 di 3 Asus ROG Ally Back Cover Replacement, Unfasten the triggers: passo 12, immagine 2 di 3 Asus ROG Ally Back Cover Replacement, Unfasten the triggers: passo 12, immagine 3 di 3
    • Use a Phillips #00 screwdriver to remove the two 3.4 mm‑long screws securing each trigger (four screws total).
    Chiedi a FixBot
    Aggiungi Commento
  13. Asus ROG Ally Back Cover Replacement, Remove the triggers: passo 13, immagine 1 di 3 Asus ROG Ally Back Cover Replacement, Remove the triggers: passo 13, immagine 2 di 3 Asus ROG Ally Back Cover Replacement, Remove the triggers: passo 13, immagine 3 di 3
    • Pull the triggers straight up and out of their recesses to remove them.
    Chiedi a FixBot
    Aggiungi Commento
  14. Asus ROG Ally Back Cover Replacement, Trigger installation: passo 14, immagine 1 di 1
    • During reassembly:
    • Compress the trigger and firmly push it into place on the chassis so the cutouts on the hinge go over their alignment posts. The trigger should stay in place.
    • Keep the trigger compressed and install the two screws.
    • Test the trigger before continuing reassembly. If it's not working properly, remove the trigger and make sure it's properly aligned on the hinge.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Spencer Day
Membro da: 09/14/22
191.426 Reputazione
1.204 guide realizzate
iFixit Membro di iFixit
Staff
122 Membri
25.947 guide realizzate
1Commento della guida
Where can one order a factory style replacement backplate? I've only been able to find the transparent version.
Brandon Gordon - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 9
Ultimi 7 giorni: 66
Ultimi 30 giorni: 312
Tutti i Tempi: 6,746
