Salta al contenuto principale
Apple Studio Display M2454 USB port replacement
Cosa ti serve
  1. Apple Studio Display M2454 USB port replacement, USB Ports: passo 1, immagine 1 di 1
    • The USB ports are located on the back side of the monitor, below the plastic cover and metallic panel; on the lower left hand side.
    • The first step is to remove the plastic cover panel.
    • To do so, remove the three 2mm hex screws on the monitor's stand, as well as the four 2mm hex screws located on the four corners of the back plastic cover panel.
    • After removing the mentioned screws, it is possible to take off the panels and began examining the inner components. Make sure main cable i pulled through plastic port.
    • For additional help removing the back panel, refer to the repair guide for the LCD Main Board.
  2. Apple Studio Display M2454 USB port replacement: passo 2, immagine 1 di 1
    • Remove the three screws holding metal plate, one on the top in the middle, and two at the bottom by the main cable.
    • Push the metal plate towards bottom of the monitor to release it from clips and remove.
    • After popping off (removing) metal plate, you can now see all inner components, where the USB connector is on left side.
  3. Apple Studio Display M2454 USB port replacement: passo 3, immagine 1 di 1
    • There are two leads from the USB port to the LCD Main Board.
    • Remove the two white connectors by raising the tabs on top gently by hand or using a small pry tool.
    • Pull connectorss away from the board while tabs are lifted.
    • Be gentle with tabs, they break easily.
  4. Apple Studio Display M2454 USB port replacement: passo 4, immagine 1 di 1
    • Remove the two phillips head screws on the sides of USB port, using #2 phillips head screwdriver.
  5. Apple Studio Display M2454 USB port replacement: passo 5, immagine 1 di 1
    • Remove the single screw on the cable hold-down, using #2 phillips head screwdriver.
  6. Apple Studio Display M2454 USB port replacement: passo 6, immagine 1 di 1
    • Finally pull USB port away from monitor.
    • To insert the new USB port, simply follow these steps in reverse using your new part.
Linea Traguardo
Dylan Perry
Membro da: 01/20/10
177 Reputazione
5 Guide realizzate
Cal Poly, Team 13-27, Maness Winter 2010 Membro di Cal Poly, Team 13-27, Maness Winter 2010
CPSU-MANESS-W10S13G27
4 Membri
9 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 21
Tutti i Tempi: 4,313
