Introduzione
Having trouble keeping consistent Wi-Fi on your tablet? If so, use this guide to replace your Wi-Fi antenna. It should also be noted that, when separating the antenna from the motherboard, there is a connection that must be desoldered before it can be fully removed.
Cosa ti serve
Use the plastic opening tool to release the clips holding the rear panel of the device onto the front section.
Continue around the entire device until all of the clips have been released.
Detach the end of the Wi-Fi antenna from the tape on the edge of the shell.
