Salta al contenuto principale
iRulu AX760 Motherboard Replacement
Cosa ti serve
  1. iRulu AX760 Motherboard Replacement, Battery: passo 1, immagine 1 di 3 iRulu AX760 Motherboard Replacement, Battery: passo 1, immagine 2 di 3 iRulu AX760 Motherboard Replacement, Battery: passo 1, immagine 3 di 3
    • Use a plastic opening tool or metal spudger to free the rear cover.
    • Insert your spudger into the side of your tablet.
    • Crack open each edge and remove the cover.
  2. iRulu AX760 Motherboard Replacement: passo 2, immagine 1 di 1
    • Open your tablet.
  3. iRulu AX760 Motherboard Replacement: passo 3, immagine 1 di 1
    • Take your plastic flat head tool and insert it under the battery.
    • Lift the battery up.
    • Make sure to remove any tape from the battery.
  4. iRulu AX760 Motherboard Replacement: passo 4, immagine 1 di 2 iRulu AX760 Motherboard Replacement: passo 4, immagine 2 di 2
    • Use a soldering iron to remove the solder that connects the black and red wires of the battery to the motherboard.
    • Keep the wires of the battery taught.
    • The iron should only be pressed to the solder for 2-3 seconds max.
    • Be very carful, the soldering iron will be very hot!
    • Visit this link for information about soldering. Come saldare e dissaldare componenti elettrici
  5. iRulu AX760 Motherboard Replacement: passo 5, immagine 1 di 1
    • Remove your old battery and replace it with the new battery.
  6. iRulu AX760 Motherboard Replacement, Motherboard: passo 6, immagine 1 di 2 iRulu AX760 Motherboard Replacement, Motherboard: passo 6, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Plastic Cards
    $2.99
    • There are two thin adhesive strips under the battery that run vertically along the left and right side.
    • Carefully wedge a plastic card or spudger under the battery and along both adhesive strips. Gently work the card or spudger up and down to free the battery.
    • Do not use metal tools, and do not bend or puncture the battery.
  7. iRulu AX760 Motherboard Replacement: passo 7, immagine 1 di 3 iRulu AX760 Motherboard Replacement: passo 7, immagine 2 di 3 iRulu AX760 Motherboard Replacement: passo 7, immagine 3 di 3
    • WARNING: SOLDERING IRONS BECOME EXTREMELY HOT. DO NOT TOUCH
    • For information on soldering and desoldering, check this link.
    • You must desolder several sets of contacts before attempting to remove the motherboard.
    • You must desolder the BAT (battery), LED, SPK (speaker), and ANT (antenna) contacts.
  8. iRulu AX760 Motherboard Replacement: passo 8, immagine 1 di 2 iRulu AX760 Motherboard Replacement: passo 8, immagine 2 di 2
    • Unscrew the motherboard from the screen with the JIS #000 Screwdriver, a Phillips-head type screwdriver
  9. iRulu AX760 Motherboard Replacement: passo 9, immagine 1 di 2 iRulu AX760 Motherboard Replacement: passo 9, immagine 2 di 2
    • Use a plastic spudger to push the tab, releasing the motherboard from the screen. You can now remove the old motherboard.
    • You will not need a metal spudger in order to re-place the motherboard
Conclusione
IUPUI, Team S6-G4, Baechle Spring 2018 Membro di IUPUI, Team S6-G4, Baechle Spring 2018
IUPUI-BAECHLE-S18S6G4
4 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 360
