Salta al contenuto principale
iPhone 5 Display Assembly Replacement Video
Guida Archiviata
Questa guida è mantenuta solo per scopi storici. Usa la versione aggiornata della guida per eseguire la riparazione.
Cosa ti serve
Panoramica Video
  1. iPhone 5 Display Assembly  Replacement Video, Taping the display glass: passo 1, immagine 1 di 3 iPhone 5 Display Assembly  Replacement Video, Taping the display glass: passo 1, immagine 2 di 3 iPhone 5 Display Assembly  Replacement Video, Taping the display glass: passo 1, immagine 3 di 3
    • Lay overlapping strips of clear packing tape over the iPhone's display until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
  2. iPhone 5 Display Assembly  Replacement Video, Remove the Pentalobe screws: passo 2, immagine 1 di 1
    • Before you proceed, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.6 mm Pentalobe screws next to the Lightning connector.
  3. iPhone 5 Display Assembly  Replacement Video, How to prevent display separation: passo 3, immagine 1 di 3 iPhone 5 Display Assembly  Replacement Video, How to prevent display separation: passo 3, immagine 2 di 3 iPhone 5 Display Assembly  Replacement Video, How to prevent display separation: passo 3, immagine 3 di 3
    • In the following steps you will be pulling the display up out of the phone body. The display is composed of a glass screen and a plastic bezel with metal clips.
    • Regardless of the tool you use, you need to be sure you pull up the entire display.
    • If the glass begins to separate from the plastic, as shown in the first image, slide a plastic opening tool between the plastic frame and the metal phone body to pry the metal clips out of the case.
    • If you are reassembling a phone with a separated display bezel, you may want to place a thin strip of adhesive between the plastic bezel and the glass to keep the phone closed.
  4. iPhone 5 Display Assembly  Replacement Video, Anti-Clamp instructions: passo 4, immagine 1 di 3 iPhone 5 Display Assembly  Replacement Video, Anti-Clamp instructions: passo 4, immagine 2 di 3 iPhone 5 Display Assembly  Replacement Video, Anti-Clamp instructions: passo 4, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Anti-Clamp
    $24.95
    Compra
    • The next two steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down two steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  5. iPhone 5 Display Assembly  Replacement Video: passo 5, immagine 1 di 3 iPhone 5 Display Assembly  Replacement Video: passo 5, immagine 2 di 3 iPhone 5 Display Assembly  Replacement Video: passo 5, immagine 3 di 3
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    • Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next two steps.
  6. iPhone 5 Display Assembly  Replacement Video, Manual Opening Procedure: passo 6, immagine 1 di 1
    • Press a suction cup onto the screen, just above the home button.
    • Be sure the cup is completely on the screen to get a tight seal.
    • If you're opening an iPhone with cracked glass, neatly lay a couple strips of packing tape across the front and squeeze out as many bubbles as you can. This will give the suction cup a surface to grab, and minimize the spread of broken glass.
  7. iPhone 5 Display Assembly  Replacement Video, Start lifting the front panel assembly: passo 7, immagine 1 di 1
    • Make sure the suction cup is firmly attached to the front panel assembly.
    • While holding the iPhone down with one hand, pull up on the suction cup to slightly separate the front panel assembly from the rear case.
    • Take your time and apply firm, constant force. The screen is a much tighter fit than most devices.
    • With a plastic opening tool, begin to gently pry the rear case down, away from the screen, while you pull up with the suction cup.
    • There are several clips attaching the front panel assembly to the rear case, so you may need to use a combination of the suction cup and plastic opening tool to free the front panel assembly.
  8. iPhone 5 Display Assembly  Replacement Video, Detaching the front panel side clips: passo 8, immagine 1 di 1
    • Continue to pry up around the sides of the front panel assembly, detaching the clips along the left and right side.
  9. iPhone 5 Display Assembly  Replacement Video, Opening up the phone: passo 9, immagine 1 di 3 iPhone 5 Display Assembly  Replacement Video, Opening up the phone: passo 9, immagine 2 di 3 iPhone 5 Display Assembly  Replacement Video, Opening up the phone: passo 9, immagine 3 di 3
    • Do not try to completely remove the front panel assembly from the rear case, as there are several ribbon cables still attached at the top of the iPhone.
    • Once the clips have been released on the bottom and sides of the front panel assembly, pull the bottom of the assembly away from the rear case.
    • Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
    • Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
  10. iPhone 5 Display Assembly  Replacement Video, Removing the battery connector bracket screws: passo 10, immagine 1 di 1
    • Remove the following two screws securing the metal battery connector bracket to the logic board:
    • One 1.8 mm Phillips screw
    • One 1.6 mm Phillips screw
  11. iPhone 5 Display Assembly  Replacement Video, Removing the battery connector bracket: passo 11, immagine 1 di 1
    • Remove the metal battery connector bracket from the iPhone.
  12. iPhone 5 Display Assembly  Replacement Video, Disconnecting the battery connector: passo 12, immagine 1 di 1
    • Use a plastic opening tool to gently pry the battery connector up from its socket on the logic board.
    • Be careful not to dislodge the small surface-mounted components surrounding the socket.
    • Be very careful to only pry up on the battery connector itself and not the socket on the logic board. If you pry up on the logic board socket or the board itself, you may destroy the socket or damage nearby components on the board.
  13. iPhone 5 Display Assembly  Replacement Video, Removing the front panel assembly cable bracket screws: passo 13, immagine 1 di 1
    • Remove the following screws securing the front panel assembly cable bracket to the logic board:
    • Two 1.2 mm Phillips screws
    • This screw tends to not be attracted to a magnetized screwdriver. Take care not to lose it when removing, and make sure it gets back into the right place—a magnetized screw may interfere with the compass.
  14. iPhone 5 Display Assembly  Replacement Video, Removing the front panel assembly cable bracket: passo 14, immagine 1 di 2 iPhone 5 Display Assembly  Replacement Video, Removing the front panel assembly cable bracket: passo 14, immagine 2 di 2
    • Lift the display cable bracket toward the battery to unhook it, and remove it from the iPhone.
    • During reassembly, clip the left-hand hooks under the logic board and lower the bracket towards the outside of the phone.
  15. iPhone 5 Display Assembly  Replacement Video, Disconnecting the front panel assembly cables: passo 15, immagine 1 di 3 iPhone 5 Display Assembly  Replacement Video, Disconnecting the front panel assembly cables: passo 15, immagine 2 di 3 iPhone 5 Display Assembly  Replacement Video, Disconnecting the front panel assembly cables: passo 15, immagine 3 di 3
    • Make sure the battery is disconnected before you disconnect or reconnect the cables in this step.
    • Use a plastic opening tool or a fingernail to disconnect the three front panel assembly cables:
    • Front-facing camera and sensor cable
    • LCD cable
    • Digitizer cable
    • When reassembling your phone, the LCD cable may pop off the connector. This can cause white lines, or nothing at all to appear when powering your phone back on. If that happens, simply reconnect the cable and power cycle your phone. The best way to power cycle your phone is to disconnect and reconnect the battery.
  16. iPhone 5 Display Assembly  Replacement Video, Separating front panel assembly and rear case: passo 16, immagine 1 di 1
    • Remove the front panel assembly from the rear case.
  17. iPhone 5 Display Assembly  Replacement Video, Earpiece Speaker: passo 17, immagine 1 di 1
    • Remove two screws securing the front-facing camera bracket to the display assembly.
    • One 4.1 mm Phillips screw
    • One 2.2 mm Phillips screw
  18. iPhone 5 Display Assembly  Replacement Video: passo 18, immagine 1 di 2 iPhone 5 Display Assembly  Replacement Video: passo 18, immagine 2 di 2
    • Remove the earpiece speaker bracket from the display assembly.
  19. iPhone 5 Display Assembly  Replacement Video: passo 19, immagine 1 di 1
    • Remove the earpiece speaker from the iPhone.
  20. iPhone 5 Display Assembly  Replacement Video: passo 20, immagine 1 di 1
    • There is a small, black plastic spacer underneath the metal bracket at the upper screw. The upper screw goes through the metal bracket then through this plastic spacer.
  21. iPhone 5 Display Assembly  Replacement Video, Front-Facing Camera and Sensor Cable: passo 21, immagine 1 di 2 iPhone 5 Display Assembly  Replacement Video, Front-Facing Camera and Sensor Cable: passo 21, immagine 2 di 2
    • Starting under the earpiece speaker contacts, use a plastic opening tool or the tip of a spudger to pry the front facing camera cable out of the display assembly.
    • Caution: Removing the earpiece speaker contacts can cause them to tear. Use extreme caution when peeling the contacts up.
  22. iPhone 5 Display Assembly  Replacement Video: passo 22, immagine 1 di 2 iPhone 5 Display Assembly  Replacement Video: passo 22, immagine 2 di 2
    • Remove the front-facing camera and rear microphone assembly.
    • If you are installing a new part, your new part may have two tabs with holes in it used for manufacturing purposes. These tabs can be cut off with scissors.
    • There is a small, square plastic and metal holder for the proximity sensor. This holder is essential for the proximity sensor to function correctly.
    • If replacing the proximity sensor or camera make sure that the holder remains adhered to the back of the display. If it comes off with the old proximity sensor, remove it from the old sensor and use a tiny bit of adhesive to re-attach it to the back of the display.
  23. iPhone 5 Display Assembly  Replacement Video, Home Button: passo 23, immagine 1 di 1
    • Remove the two 1.3 mm Phillips screws securing the home button bracket to the display assembly.
  24. iPhone 5 Display Assembly  Replacement Video: passo 24, immagine 1 di 2 iPhone 5 Display Assembly  Replacement Video: passo 24, immagine 2 di 2
    • Gently flip the home button bracket to the right.
  25. iPhone 5 Display Assembly  Replacement Video: passo 25, immagine 1 di 1
    • Gently press up on the center of the home button from the display side of the display assembly, to loosen the adhesive securing it to the assembly.
  26. iPhone 5 Display Assembly  Replacement Video: passo 26, immagine 1 di 3 iPhone 5 Display Assembly  Replacement Video: passo 26, immagine 2 di 3 iPhone 5 Display Assembly  Replacement Video: passo 26, immagine 3 di 3
    • Once the home button has started to separate from the display assembly, use the tip of a spudger to completely lift the button from the adhesive securing it.
    • Be careful not to tear the rubber gasket surrounding the home button.
    • Remove the home button from the display assembly.
Conclusione
Altre 18 persone hanno completato questa guida.
ZFix
Membro da: 12/09/13
191.308 Reputazione
330 Guide realizzate
Master Techs Membro di Master Techs
Community
322 Membri
2.532 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 12,992
