Introduzione
Guida prerequisita in caso di rimozione della scheda logica.
Cosa ti serve
Rimuovi le due viti Phillips da 2,4 mm dai lati del gruppo altoparlante.
Rimuovi la piccola staffa in plastica che era posizionata sotto la vite più vicina al cavo del connettore del dock.
Rounded screw on the black metal piece.... fml what should i do
I could not see it and flipping over the phone, or what’s left of it, it dropped. Where to put it back though ?
Rimuovi il gruppo altoparlante dall'iPhone.
Careful not to lose the tiny rubber spacer that sits below the mic enclosure - I nearly did as it is not mentioned here, probably because it rarely comes out. See mention and photo of this in this guide, step 20: Dock Connector Replacement
I had some problems with the cellular cable during re-installation. It actually had gotten scratched to where the wire was actually worn and the silver cable was visible. I discovered this once it was all closed and the phone's cellular status was always "Searching...". A little bit of electrical tape over the exposed area seemed to take care of this.
I "lost" one of the screws securing the speaker, but re-assembled it anyway without the RH screw. Everything worked; then I realised where it might have gone. The speaker has a magnet which will attract any loose screws nearby. Sure enough, that's where I found it when I opened it up again.
I was trying to get the little triangle spacer in place to get the speakers installed. I had it in some tweezers trying to see what I was doing wearing some magnifying goggles, when the spacer shot out like a watermelon seed from between your fingers....Never got a clear view of where i went but it looked like it went sailing over into a part of the room where there is loads of little small bits+pieces in loads of other bigger boxes and containers...it sailed off into the land of the lost. I'd be lucky to happen to see the little booger during spring cleaning...I won't hold my breath. Anybody know where i can buy such a thing?
edit- I made a replacement out of some scrap plastic . Doesn't look too bad. Not sure about thickness. So I'm just gonna put everything back together and hope for the best.
buy a equal phone that is perhaps destroyed AND locked . that is how I have replaced many parts I have done what you have done . I now have parts I may never use but ... who knows I just aim for the phones I have extra parts for
As ++hutchwilco++ mentioned don’t forget to put back the rubber spacer on the bottom right side of the speaker (as seen on picture from step 29). Comes on the bottom of it, between metal bezel and speaker.It is a marking on the speaker.
I’ve seen mine and I have struggled to find it’s place.
Per rimontare il tuo dispositivo, segui queste istruzioni in ordine inverso.
Altre 3 persone hanno completato questa guida.
Un ringraziamento speciale a questi traduttori:
100%
Questi traduttori ci stanno aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
