Introduzione
Use this guide to replace the FaceTime camera in your 21.5" Retina 4K 2017 iMac.
Some images in this guide use a 2015 iMac, which has minor visual differences. These differences do not affect the repair procedure.
Cosa ti serve
Attrezzo utilizzato in questo passaggio:iMac Intel 21.5" Cardboard Service Wedge$4.99
Before beginning any work on your iMac: Unplug the computer and press and hold the power button for ten seconds to discharge the power supply's capacitors.
Attrezzo utilizzato in questo passaggio:Plastic Cards$2.99
Starting from the top right corner of the iMac, wedge a plastic card between the display and frame.
Hold the display with one hand while using your other hand to unplug the display power cable.
Use the tip of a spudger to flip down the metal retaining bracket on the camera cable.
Remove the two 4.3 mm T5 Torx screws securing the camera board to the top of the rear enclosure.
To reassemble your device, follow these instructions in reverse.
