Salta al contenuto principale
iMac 27" 2017 RAM Replacement
Cosa ti serve
  1. iMac 27" 2017 RAM Replacement, Open the RAM door: passo 1, immagine 1 di 2 iMac 27" 2017 RAM Replacement, Open the RAM door: passo 1, immagine 2 di 2
    • While holding the display steady, use the flat end of a spudger to press in on the RAM door release button, located just above the power port.
    • You may have to press fairly hard—keep at it until the bottom of the door pops out about 0.25" from the rear of the iMac.
    Chiedi a FixBot
    Aggiungi Commento
  2. iMac 27" 2017 RAM Replacement, Remove the RAM door: passo 2, immagine 1 di 3 iMac 27" 2017 RAM Replacement, Remove the RAM door: passo 2, immagine 2 di 3 iMac 27" 2017 RAM Replacement, Remove the RAM door: passo 2, immagine 3 di 3
    • Pull the RAM access door off the back of the iMac.
    Chiedi a FixBot
    Aggiungi Commento
  3. iMac 27" 2017 RAM Replacement, Unlock the RAM tray: passo 3, immagine 1 di 3 iMac 27" 2017 RAM Replacement, Unlock the RAM tray: passo 3, immagine 2 di 3 iMac 27" 2017 RAM Replacement, Unlock the RAM tray: passo 3, immagine 3 di 3
    • The RAM tray is locked into its upright position with two grey tabs.
    • Use your thumbs or index fingers to unlock the tray by pushing the tabs outward, away from the RAM.
    • Pull the tabs out and down, swinging the RAM tray down to a near-horizontal position.
    Chiedi a FixBot
    Aggiungi Commento
  4. iMac 27" 2017 RAM Replacement, Remove the RAM: passo 4, immagine 1 di 3 iMac 27" 2017 RAM Replacement, Remove the RAM: passo 4, immagine 2 di 3 iMac 27" 2017 RAM Replacement, Remove the RAM: passo 4, immagine 3 di 3
    • Remove a stick of RAM by grabbing it with two hands and pulling straight out of the RAM tray.
    • RAM modules are keyed so that they can only be installed in the proper orientation. Note where the shorter section of contacts is when removing, and reinstalling, your RAM.
    • To install a new module, insert the module into the desired slot in the tray and press it firmly in place. Push the tray back up until it locks in place.
    • The RAM access door is not symmetrical. If it is not flush on both ends, try putting it in the other way.
    • Re-insert the RAM access door back into its place.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 6 persone hanno completato questa guida.
Adam O'Camb
Membro da: 04/11/15
223.264 Reputazione
416 guide realizzate
2Commenti sulla guida
Thanks Arthur, I got them
walser1 - Rispondi Condividi
bom dia, posso trocar a memoria de 2444MHZ para 2666MHZ? 3000MHZ ?
MARCELO MIRA - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 5
Ultimi 7 giorni: 63
Ultimi 30 giorni: 219
Tutti i Tempi: 21,250
