Salta al contenuto principale
iHome iM71SC Base LED Replacement
Cosa ti serve
  1. iHome iM71SC Base LED Replacement, iHome iM71SC Disassembly: passo 1, immagine 1 di 1
    • Push down and turn the top of the speaker clockwise. This will release the clips and expand the speaker.
  2. iHome iM71SC Base LED Replacement: passo 2, immagine 1 di 1
    • Use a #000 Phillips screwdriver to remove the four 1 mm screws from the bottom half of the speaker.
  3. iHome iM71SC Base LED Replacement: passo 3, immagine 1 di 1
    • Flip the speaker over and use a #000 Phillips screwdriver to remove three 1mm screws . Unscrew these to unfasten the top.
  4. iHome iM71SC Base LED Replacement: passo 4, immagine 1 di 1
    • Remove the now unfastened coverings to expose the internals of the speaker.
  5. iHome iM71SC Base LED Replacement, Base LED: passo 5, immagine 1 di 1
    • Locate the LED on the circuit board.
  6. iHome iM71SC Base LED Replacement: passo 6, immagine 1 di 2 iHome iM71SC Base LED Replacement: passo 6, immagine 2 di 2
    • Desolder the three connections to the old LED to remove it from the board.
    • Check out this awesome guide for soldering & desoldering instructions.
Conclusione
To reassemble your device, follow Steps 1-4 in reverse order.
Sarah Brown
Membro da: 03/21/17
301 Reputazione
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 8
Tutti i Tempi: 221
