Salta al contenuto principale
iHome iAVS16 Speakers Replacement
Cosa ti serve
  1. iHome iAVS16 Speakers Replacement, Power Board: passo 1, immagine 1 di 3 iHome iAVS16 Speakers Replacement, Power Board: passo 1, immagine 2 di 3 iHome iAVS16 Speakers Replacement, Power Board: passo 1, immagine 3 di 3
    • Remove the four 1.7 mm Phillips #0 screws located on the bottom of the device.
    • Lift up the bottom of the device.
    • Carefully lift the bottom of the device up as to not damage the ribbon cable connecting it.
  2. iHome iAVS16 Speakers Replacement: passo 2, immagine 1 di 3 iHome iAVS16 Speakers Replacement: passo 2, immagine 2 di 3 iHome iAVS16 Speakers Replacement: passo 2, immagine 3 di 3
    • Remove the two 1.7 mm Phillips #0 screws holding the white face place onto the inside of the device's bottom.
    • Using an iFixit opening tool on the side without the black adhesive, carefully lift up the white face plate.
    • Lifting too quickly could damage the ribbon cable still attached.
  3. iHome iAVS16 Speakers Replacement: passo 3, immagine 1 di 2 iHome iAVS16 Speakers Replacement: passo 3, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Using the tweezers, lift up on the black tab holding the ribbon cable down.
    • Carefully pull the ribbon cable back and out of the slot.
  4. iHome iAVS16 Speakers Replacement: passo 4, immagine 1 di 3 iHome iAVS16 Speakers Replacement: passo 4, immagine 2 di 3 iHome iAVS16 Speakers Replacement: passo 4, immagine 3 di 3
    • Remove the two 1.7 mm Phillips #0 screws holding the power board in.
    • Carefully flip the board over.
    • Remove the red connector from its socket with a pair of tweezers.
  5. iHome iAVS16 Speakers Replacement, LCD (Display): passo 5, immagine 1 di 3 iHome iAVS16 Speakers Replacement, LCD (Display): passo 5, immagine 2 di 3 iHome iAVS16 Speakers Replacement, LCD (Display): passo 5, immagine 3 di 3
    • Insert an iFixit opening tool into the lining on the front casing and pry it apart. Do this for both sides.
    • Further remove the front casing off from the device manually with your hands.
  6. iHome iAVS16 Speakers Replacement: passo 6, immagine 1 di 1
    • Remove the four 1.7 mm Phillips #0 screws holding the LCD onto the front of the device.
  7. iHome iAVS16 Speakers Replacement: passo 7, immagine 1 di 3 iHome iAVS16 Speakers Replacement: passo 7, immagine 2 di 3 iHome iAVS16 Speakers Replacement: passo 7, immagine 3 di 3
    • Carefully flip the LCD display over to expose the ribbon cable connecting it.
    • Lift the black tab holding the cable down, and carefully put it out of the socket.
  8. iHome iAVS16 Speakers Replacement, Motherboard: passo 8, immagine 1 di 1
    • Flip up the back of the device encasing the motherboard.
  9. iHome iAVS16 Speakers Replacement: passo 9, immagine 1 di 3 iHome iAVS16 Speakers Replacement: passo 9, immagine 2 di 3 iHome iAVS16 Speakers Replacement: passo 9, immagine 3 di 3
    Compra
    • Using tweezers, unplug the white, red, and blue connectors from the motherboard by pulling each out.
  10. iHome iAVS16 Speakers Replacement: passo 10, immagine 1 di 1
    • Carefully unplug the ribbon cable, making sure not to rip it.
  11. iHome iAVS16 Speakers Replacement, Wi-Fi Antenna: passo 11, immagine 1 di 3 iHome iAVS16 Speakers Replacement, Wi-Fi Antenna: passo 11, immagine 2 di 3 iHome iAVS16 Speakers Replacement, Wi-Fi Antenna: passo 11, immagine 3 di 3
    • Using an iFixit opening tool, push the tab under the top of the device to create a gap.
    • Sometimes the top will pop off easily, and other times it will not. You may need to hold the tab up while you insert the iFixit opening tool under the top lining.
    • Insert the iFixit opening tool in the gap, and slide it across to remove the top casing.
  12. iHome iAVS16 Speakers Replacement: passo 12, immagine 1 di 3 iHome iAVS16 Speakers Replacement: passo 12, immagine 2 di 3 iHome iAVS16 Speakers Replacement: passo 12, immagine 3 di 3
    • Remove the top cover of the device.
    • Remove the five 1.7 mm Phillips #0 screws on the top of the device.
  13. iHome iAVS16 Speakers Replacement: passo 13, immagine 1 di 3 iHome iAVS16 Speakers Replacement: passo 13, immagine 2 di 3 iHome iAVS16 Speakers Replacement: passo 13, immagine 3 di 3
    Compra
    • Remove the Wi-Fi antenna with tweezers.
    • You may wish to completely remove the motherboard for easier access to the Wi-Fi chip and antenna. Please refer to motherboard guide for instructions.
  14. iHome iAVS16 Speakers Replacement, Speakers: passo 14, immagine 1 di 2 iHome iAVS16 Speakers Replacement, Speakers: passo 14, immagine 2 di 2
    • Remove the four Phillips screws on the back of the front half of the device holding the speakers in.
    • The speakers are magnetic so removing the screws can be challenging.
    • Push the speakers out of the back of the device.
  15. iHome iAVS16 Speakers Replacement: passo 15, immagine 1 di 2 iHome iAVS16 Speakers Replacement: passo 15, immagine 2 di 2
    • assemble it back together
Conclusione
Thank you for using our guide, we hope that it helped you fix your project
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 12
Tutti i Tempi: 184
