Introduzione
The iHome iAVS16 is an Amazon Alexa enabled bedside/office alarm clock capable of setting alarms, telling time and date, as well as playing music and controlling smart devices within the home via voice commands. This guide will show you how to disassemble the iHome iAVS16 bedside clock to access the motherboard in case of failure. Before beginning, make sure to power off the device completely and disconnect from any external power source.
Cosa ti serve
Remove the four 1.7 mm Phillips #0 screws located on the bottom of the device.
Lift up the bottom of the device.
Insert an iFixit opening tool into the lining on the front casing and pry it apart. Do this for both sides.
Further remove the front casing off from the device manually with your hands.
