Salta al contenuto principale
iHome IH11 Speaker Replacement
Cosa ti serve
  1. iHome IH11 Speaker Replacement, Outer Case: passo 1, immagine 1 di 1
    • Unscrew the two 9.0 mm screws with a Phillips #1 screwdriver.
    • Remove the translucent bottom case.
  2. iHome IH11 Speaker Replacement: passo 2, immagine 1 di 2 iHome IH11 Speaker Replacement: passo 2, immagine 2 di 2
    • Remove the two 9.0mm screws on the back of the iHome with a Phillips #1 screwdriver.
    • Repeat the previous step for the two 9.0mm screws on the bottom.
    • Carefully slide the back cover off. There are wires connected to the back cover.
  3. iHome IH11 Speaker Replacement: passo 3, immagine 1 di 1
    • Remove the two 12.0mm screws holding the speaker to the iHome with a Phillips #1 screwdriver.
  4. iHome IH11 Speaker Replacement: passo 4, immagine 1 di 2 iHome IH11 Speaker Replacement: passo 4, immagine 2 di 2
    • Remove the four 12.0mm screws on the face of the speaker with the Phillips #1 Screwdriver.
    • Carefully lift speaker out of its casing.
  5. iHome IH11 Speaker Replacement: passo 5, immagine 1 di 1
    • Unsolder the two wires that connect to the speaker.
Conclusione
Cal Poly, Team 14-9, Maness Spring 2013 Membro di Cal Poly, Team 14-9, Maness Spring 2013
CPSU-MANESS-S13S14G9
5 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 12
Tutti i Tempi: 343
