Salta al contenuto principale
iHome IH11 Main Motherboard Replacement
Cosa ti serve
  1. iHome IH11 Main Motherboard Replacement, Outer Case: passo 1, immagine 1 di 1
    • Unscrew the two 9.0 mm screws with a Phillips #1 screwdriver.
    • Remove the translucent bottom case.
  2. iHome IH11 Main Motherboard Replacement: passo 2, immagine 1 di 2 iHome IH11 Main Motherboard Replacement: passo 2, immagine 2 di 2
    • Remove the two Phillips #1 9.0mm screws on the back of the iHome.
    • Repeat the previous step for the two 9.0mm screws on the bottom.
    • Carefully slide the back cover off. There are wires connected to the back cover.
  3. iHome IH11 Main Motherboard Replacement: passo 3, immagine 1 di 1
    • Remove the aluminum bracket by loosening the two nuts and removing the 8.0 mm bolts.
    • Pull the bracket out.
  4. iHome IH11 Main Motherboard Replacement: passo 4, immagine 1 di 2 iHome IH11 Main Motherboard Replacement: passo 4, immagine 2 di 2
    • Remove the two 12.0mm screws that hold the motherboard with a Phillips #1 screwdriver.
    • Slide the motherboard gently out.
  5. iHome IH11 Main Motherboard Replacement: passo 5, immagine 1 di 1
    • Solder each wire to corresponding input on the motherboard.
Conclusione
Cal Poly, Team 14-9, Maness Spring 2013 Membro di Cal Poly, Team 14-9, Maness Spring 2013
CPSU-MANESS-S13S14G9
5 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 13
Tutti i Tempi: 382
