Salta al contenuto principale
iHome IH11 AC Power Adapter Replacement
Cosa ti serve
  1. iHome IH11 AC Power Adapter Replacement, Outer Case: passo 1, immagine 1 di 1
    • Unscrew the two 9.0 mm screws with the Phillips #1.
    • Remove the translucent bottom plastic piece.
  2. iHome IH11 AC Power Adapter Replacement: passo 2, immagine 1 di 2 iHome IH11 AC Power Adapter Replacement: passo 2, immagine 2 di 2
    • Remove the two 9.0mm screws on the back of the iHome with the Phillips #1 screwdriver.
    • Repeat the previous step for the two 9.0mm screws on the bottom.
    • Carefully slide the back cover off. There are wires attached to the back cover.
  3. iHome IH11 AC Power Adapter Replacement: passo 3, immagine 1 di 1
    • Remove the aluminum bracket by loosening the two nuts and removing the 8.0mm bolts with your hand.
  4. iHome IH11 AC Power Adapter Replacement, Motherboard: passo 4, immagine 1 di 2 iHome IH11 AC Power Adapter Replacement, Motherboard: passo 4, immagine 2 di 2
    • Remove the two 12.0mm screws that hold the motherboard with the Phillips #1 screwdriver.
    • Slide the motherboard gently out.
  5. iHome IH11 AC Power Adapter Replacement: passo 5, immagine 1 di 1
    • Remove the two 9.0 mm screws with the Phillips #1 screwdriver, then slide the circuit board for the AC adapter out.
    • Repeat the previous step by removing the two 9.0mm screws with the Phillips #1 screwdriver for the circuit board for the on/off switch.
  6. iHome IH11 AC Power Adapter Replacement: passo 6, immagine 1 di 2 iHome IH11 AC Power Adapter Replacement: passo 6, immagine 2 di 2
    • Unsolder the main connections holding the AC adapter to the circuit board.
    • Solder new adapter in same position with same connections.
Conclusione
Altre 2 persone hanno completato questa guida.
Nick Knowles
Membro da: 04/19/13
21 Reputazione
2 Guide realizzate
Cal Poly, Team 14-9, Maness Spring 2013 Membro di Cal Poly, Team 14-9, Maness Spring 2013
CPSU-MANESS-S13S14G9
5 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 808
