Introduzione
Motherboard is the most important component of a Zoomer Jurassic World Indominus Rex. If all else fails, we can always replace the motherboard. Knowing how to solder before attempting this guide is extremely encouraged. Details about soldering technique guide can be found at the last step of this guide.
Cosa ti serve
Remove all eight (8) 9.3mm Phillips screws using Phillips #1 screwdriver.
Attrezzo utilizzato in questo passaggio:Tweezers$4.99
Gently pull each wire out of the connector on the motherboard. Use a set of tweezers, if necessary.
