Salta al contenuto principale
Zoomer Jurassic World Indominus Rex Eye LED Replacement
Cosa ti serve
  1. Zoomer Jurassic World Indominus Rex Eye LED Replacement, Mouth Part: passo 1, immagine 1 di 2 Zoomer Jurassic World Indominus Rex Eye LED Replacement, Mouth Part: passo 1, immagine 2 di 2
    • Flip the toy over to gain direct access to the first screws you need to remove for the replacement.
    • Remove the two (2) 7.5mm phillips screws using Phillips #1 screwdriver from the bottom of the jaw.
    • Remove the two (2) 7.2mm phillips screws using Phillips #0 screwdriver from the bottom of the jaw.
    • Gently remove the entire bottom jaw piece.
  2. Zoomer Jurassic World Indominus Rex Eye LED Replacement: passo 2, immagine 1 di 3 Zoomer Jurassic World Indominus Rex Eye LED Replacement: passo 2, immagine 2 di 3 Zoomer Jurassic World Indominus Rex Eye LED Replacement: passo 2, immagine 3 di 3
    • Remove the 7.5mm phillips screw using Phillips #1 screwdriver from the middle of the tongue.
    • Using a spudger, gently pry the tongue out of the mouth.
  3. Zoomer Jurassic World Indominus Rex Eye LED Replacement, Eye LED: passo 3, immagine 1 di 2 Zoomer Jurassic World Indominus Rex Eye LED Replacement, Eye LED: passo 3, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Remove the four (4) 7.5mm Phillips screws from the pieces holding the circuit board for the LEDs in place.
    • Use tweezers to pull the circuit board out of place.
    • Pull directly upward! Be careful not to break the circuit board during removal.
  4. Zoomer Jurassic World Indominus Rex Eye LED Replacement: passo 4, immagine 1 di 1
    • Use a soldering iron to disconnect the four (4) wires from the circuit board.
    • Soldering technique guide from iFixit can be found here.
    • Be careful not to burn yourself or the plastic while soldering!
Conclusione
Luke Selby
Membro da: 01/20/16
636 Reputazione
4 Guide realizzate
USF Tampa, Team 10-3, Remmell Spring 2016 Membro di USF Tampa, Team 10-3, Remmell Spring 2016
USFT-REMMELL-S16S10G3
4 Membri
14 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 46
Tutti i Tempi: 638
