Salta al contenuto principale
Zoomer Dino Boomer Nose Sensor Replacement
Cosa ti serve
  1. Zoomer Dino Boomer Nose Sensor Replacement, Nose Sensor: passo 1, immagine 1 di 2 Zoomer Dino Boomer Nose Sensor Replacement, Nose Sensor: passo 1, immagine 2 di 2
    • Unscrew the two 7.5 mm Phillips #0 screws at the base of the neck.
    • Remove the two 7.2 mm Phillips #0 screws above these at the base of the mouth.
  2. Zoomer Dino Boomer Nose Sensor Replacement: passo 2, immagine 1 di 2 Zoomer Dino Boomer Nose Sensor Replacement: passo 2, immagine 2 di 2
    • Use the spudger to pry Zoomer Dino Boomer's lower jaw from its mouth.
  3. Zoomer Dino Boomer Nose Sensor Replacement: passo 3, immagine 1 di 2 Zoomer Dino Boomer Nose Sensor Replacement: passo 3, immagine 2 di 2
    • Remove the roof of Zoomer Dino Boomer's mouth by unscrewing the 7.5 mm Phillips #0 screw.
  4. Zoomer Dino Boomer Nose Sensor Replacement: passo 4, immagine 1 di 2 Zoomer Dino Boomer Nose Sensor Replacement: passo 4, immagine 2 di 2
    • Carefully push the sensors out of the nose socket with your fingers.
  5. Zoomer Dino Boomer Nose Sensor Replacement: passo 5, immagine 1 di 3 Zoomer Dino Boomer Nose Sensor Replacement: passo 5, immagine 2 di 3 Zoomer Dino Boomer Nose Sensor Replacement: passo 5, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    • Use a soldering iron to remove the wires from the sensor chip by melting the metal joints on the chip.
    • Use the tweezers to remove the wires as you are soldering them.
    • Do not touch any parts of Zoomer Dino Boomer or yourself when using the soldering iron. The soldering iron will be very hot.
    • When reassembling, extra solder may be required to reconnect the wires with the circuit board.
  6. Zoomer Dino Boomer Nose Sensor Replacement: passo 6, immagine 1 di 1
    • Remove and replace the nose sensor.
Conclusione
USF Tampa, Team 16-1, Wollert Fall 2015 Membro di USF Tampa, Team 16-1, Wollert Fall 2015
USFT-WOLLERT-F15S16G1
3 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 17
Tutti i Tempi: 1,430
