Salta al contenuto principale
Zoom H1 Handy Recorder Speaker Replacement
Cosa ti serve
  1. Zoom H1 Handy Recorder Speaker Replacement, Speaker: passo 1, immagine 1 di 1
    • Turn the device over with its display down.
  2. Zoom H1 Handy Recorder Speaker Replacement: passo 2, immagine 1 di 1
    • Remove the battery cover, pressing down on the tabs and sliding.
  3. Zoom H1 Handy Recorder Speaker Replacement: passo 3, immagine 1 di 1
    • Unscrew the two (2) #00, 10 mm screws located below the mic on the back cover.
  4. Zoom H1 Handy Recorder Speaker Replacement: passo 4, immagine 1 di 1
    • Carefully pry up the top end of the back cover using one finger.
  5. Zoom H1 Handy Recorder Speaker Replacement: passo 5, immagine 1 di 1
    • Remove the back plate by using a plastic removal tool to pry the back cover up around the edges.
  6. Zoom H1 Handy Recorder Speaker Replacement: passo 6, immagine 1 di 1
    • De-solder the white and black speaker wires from their soldering points.
    • Speaker soldering points are located on the thin section of the blue circuit board, and are marked with “SP+” and “SP-”.
    • Keep in mind which color wire was connected at which terminal.
  7. Zoom H1 Handy Recorder Speaker Replacement: passo 7, immagine 1 di 1
    • Remove the damaged speaker from its place at the very bottom of the case, just below the battery input.
    • You will have to break the glue holding the speaker in place before removing it.
  8. Zoom H1 Handy Recorder Speaker Replacement: passo 8, immagine 1 di 1
    • Replace the damaged speaker and re-solder to the original solder points.
    • Ensure that the negative wire is soldered to the “SP-” while the positive wire is soldered to the “SP+” point.
Conclusione
Alex
Membro da: 10/28/13
809 Reputazione
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 1,698
