Salta al contenuto principale
Zenbre SoundBank Z3 Speaker Replacement
Cosa ti serve
  1. Zenbre SoundBank Z3 Speaker Replacement, Bottom Cover: passo 1, immagine 1 di 2 Zenbre SoundBank Z3 Speaker Replacement, Bottom Cover: passo 1, immagine 2 di 2
    • Power off the SoundBank Z3.
    • Turn over the device.
    • Peel the silicone feet up to remove.
    • No extra adhesive is needed to reapply the feet as long as the sticky side is not touched.
  2. Zenbre SoundBank Z3 Speaker Replacement: passo 2, immagine 1 di 1
    • Remove all eight of the 11 mm Phillips screws from the bottom of the device.
  3. Zenbre SoundBank Z3 Speaker Replacement: passo 3, immagine 1 di 2 Zenbre SoundBank Z3 Speaker Replacement: passo 3, immagine 2 di 2
    • Remove the bottom panel speaker using an iFixit opening tool.
  4. Zenbre SoundBank Z3 Speaker Replacement, Motherboard Cover: passo 4, immagine 1 di 3 Zenbre SoundBank Z3 Speaker Replacement, Motherboard Cover: passo 4, immagine 2 di 3 Zenbre SoundBank Z3 Speaker Replacement, Motherboard Cover: passo 4, immagine 3 di 3
    • Remove the four 4.5 mm silver Phillips screws that secure the plastic panel covering the motherboard.
    • Remove the plastic panel.
  5. Zenbre SoundBank Z3 Speaker Replacement, Speakers: passo 5, immagine 1 di 2 Zenbre SoundBank Z3 Speaker Replacement, Speakers: passo 5, immagine 2 di 2
    • Remove the three screws that are holding the speaker down.
    • Be careful not to rip out the speaker while taking out the screws.
  6. Zenbre SoundBank Z3 Speaker Replacement: passo 6, immagine 1 di 2 Zenbre SoundBank Z3 Speaker Replacement: passo 6, immagine 2 di 2
    • Desolder the speaker joints from the motherboard. Follow this How To Solder guide for help with desoldering.
  7. Zenbre SoundBank Z3 Speaker Replacement: passo 7, immagine 1 di 2 Zenbre SoundBank Z3 Speaker Replacement: passo 7, immagine 2 di 2
    • Remove the speaker from the motherboard.
    • Remove the speaker ring.
    • Be careful not to remove other components in the speaker.
    • Repeat Steps 5-7 with the other speaker.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 488
