Salta al contenuto principale
Zenbre SoundBank Z3 Speaker Grill Replacement
Cosa ti serve
  1. Zenbre SoundBank Z3 Speaker Grill Replacement, Bottom Cover: passo 1, immagine 1 di 2 Zenbre SoundBank Z3 Speaker Grill Replacement, Bottom Cover: passo 1, immagine 2 di 2
    • Power off the SoundBank Z3.
    • Turn over the device.
    • Peel the silicone feet up to remove.
    • No extra adhesive is needed to reapply the feet as long as the sticky side is not touched.
  2. Zenbre SoundBank Z3 Speaker Grill Replacement: passo 2, immagine 1 di 1
    • Remove all eight of the 11 mm Phillips screws from the bottom of the device.
  3. Zenbre SoundBank Z3 Speaker Grill Replacement: passo 3, immagine 1 di 2 Zenbre SoundBank Z3 Speaker Grill Replacement: passo 3, immagine 2 di 2
    • Remove the bottom panel speaker using an iFixit opening tool.
  4. Zenbre SoundBank Z3 Speaker Grill Replacement, Motherboard Cover: passo 4, immagine 1 di 3 Zenbre SoundBank Z3 Speaker Grill Replacement, Motherboard Cover: passo 4, immagine 2 di 3 Zenbre SoundBank Z3 Speaker Grill Replacement, Motherboard Cover: passo 4, immagine 3 di 3
    • Remove the four 4.5 mm silver Phillips screws that secure the plastic panel covering the motherboard.
    • Remove the plastic panel.
  5. Zenbre SoundBank Z3 Speaker Grill Replacement, Speaker Grill: passo 5, immagine 1 di 3 Zenbre SoundBank Z3 Speaker Grill Replacement, Speaker Grill: passo 5, immagine 2 di 3 Zenbre SoundBank Z3 Speaker Grill Replacement, Speaker Grill: passo 5, immagine 3 di 3
    • Remove the three silver Phillips screws from the plastic ring that holds the speaker in place.
    • Be careful not to rip out the speaker while taking out the screws
    • The same steps can be done on the other side of the speaker
  6. Zenbre SoundBank Z3 Speaker Grill Replacement: passo 6, immagine 1 di 3 Zenbre SoundBank Z3 Speaker Grill Replacement: passo 6, immagine 2 di 3 Zenbre SoundBank Z3 Speaker Grill Replacement: passo 6, immagine 3 di 3
    • First, remove the speaker from the motherboard, then remove the ring that held the speaker in place.
    • These are the joints that need to be soldered. Follow this guide link to help you remove the wires from the motherboard.
    • How To Solder and Desolder Connections
  7. Zenbre SoundBank Z3 Speaker Grill Replacement: passo 7, immagine 1 di 2 Zenbre SoundBank Z3 Speaker Grill Replacement: passo 7, immagine 2 di 2
    • With the plastic ring removed, the speaker should slide out easily.
    • Be careful not remove other components in the speaker
    • This will expose the speaker grill
  8. Zenbre SoundBank Z3 Speaker Grill Replacement: passo 8, immagine 1 di 3 Zenbre SoundBank Z3 Speaker Grill Replacement: passo 8, immagine 2 di 3 Zenbre SoundBank Z3 Speaker Grill Replacement: passo 8, immagine 3 di 3
    • Now that the speaker has been removed, the plastic grill should be visible.
    • With a little bit of force they can be pushed out.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 537
