Salta al contenuto principale
Zeki Droid Tablet Front Screen Replacement
Cosa ti serve
  1. Zeki Droid Tablet Front Screen Replacement, Back Casing: passo 1, immagine 1 di 1
    • Remove the back casing by slowly popping each tab out with a plastic opening tool.
  2. Zeki Droid Tablet Front Screen Replacement: passo 2, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Remove the tapes one by one from the connecting wires with tweezers.
  3. Zeki Droid Tablet Front Screen Replacement: passo 3, immagine 1 di 1
    • Remove the black clips from both sides of the casing with a plastic opening tool.
    • The clips should pop off separate from the speakers.
  4. Zeki Droid Tablet Front Screen Replacement: passo 4, immagine 1 di 1
    • Remove the speakers from the back casing.
    • Do not tug on the speakers because they are connected to fragile wires.
  5. Zeki Droid Tablet Front Screen Replacement: passo 5, immagine 1 di 1
    • Pull the speakers away from the back casing carefullly.
  6. Zeki Droid Tablet Front Screen Replacement, Front Screen: passo 6, immagine 1 di 1
    • Detach the motherboard from the framing by removing the four screws using a Phillips #000 screwdriver.
  7. Zeki Droid Tablet Front Screen Replacement: passo 7, immagine 1 di 1
    • Lift the camera and flash components from their fittings using tweezers.
  8. Zeki Droid Tablet Front Screen Replacement: passo 8, immagine 1 di 1
    • Lift the metal framing to reach the components at the front of the device.
    • Do not pull the framing completely off. There is a ZIF connecter holding it in place.
  9. Zeki Droid Tablet Front Screen Replacement: passo 9, immagine 1 di 2 Zeki Droid Tablet Front Screen Replacement: passo 9, immagine 2 di 2
    • Push the screen forward to remove.
Conclusione
Kyla
Membro da: 03/11/15
156 Reputazione
2 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 405
