Salta al contenuto principale
Zeki Droid Tablet Camera Replacement
Cosa ti serve
  1. Zeki Droid Tablet Camera Replacement, Back Casing: passo 1, immagine 1 di 1
    • Remove the back casing by slowly popping each tab out with a plastic opening tool.
  2. Zeki Droid Tablet Camera Replacement: passo 2, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Remove the tapes one by one from the connecting wires with tweezers.
  3. Zeki Droid Tablet Camera Replacement: passo 3, immagine 1 di 1
    • Remove the black clips from both sides of the casing with a plastic opening tool.
    • The clips should pop off separate from the speakers.
  4. Zeki Droid Tablet Camera Replacement: passo 4, immagine 1 di 1
    • Remove the speakers from the back casing.
    • Do not tug on the speakers because they are connected to fragile wires.
  5. Zeki Droid Tablet Camera Replacement: passo 5, immagine 1 di 1
    • Pull the speakers away from the back casing carefullly.
  6. Zeki Droid Tablet Camera Replacement, Camera: passo 6, immagine 1 di 2 Zeki Droid Tablet Camera Replacement, Camera: passo 6, immagine 2 di 2
    • Grip the camera on both sides using tweezers or your fingers, and carefully lift it off the board.
    • The adhesive may make it difficult to remove the cameras from the tablet.
  7. Zeki Droid Tablet Camera Replacement: passo 7, immagine 1 di 1
    • Undo the ZIF connector that is connecting the cameras to the motherboard using a plastic spudger or fingernail.
    • This guide has more information on how to undo the ZIF connector
    • Do not yank the ZIF connector. It should come apart very easily with little force needed.
  8. Zeki Droid Tablet Camera Replacement: passo 8, immagine 1 di 1
    • Pull the copper connection carefully away from the motherboard of the tablet to completely remove the camera.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 464
