Salta al contenuto principale
Zeepad 7.0 Screen Replacement
Cosa ti serve
  1. Zeepad 7.0 Screen Replacement, Screen: passo 1, immagine 1 di 2 Zeepad 7.0 Screen Replacement, Screen: passo 1, immagine 2 di 2
    • Power off the device and keep it unplugged.
    • Open the case using a plastic opening tool around the edges. Slightly pull the cover off.
    • Do not completely remove back casing because there is a speaker attached to the back.
  2. Zeepad 7.0 Screen Replacement: passo 2, immagine 1 di 1
    • Using the Phillips Head 0 bit, carefully unscrew the three 3.5mm screws holding the motherboard in place on to the back of the screen.
  3. Zeepad 7.0 Screen Replacement: passo 3, immagine 1 di 2 Zeepad 7.0 Screen Replacement: passo 3, immagine 2 di 2
    • Disconnect the two ribbon cables between the screen and the motherboard.
    • Be careful not to rip out the ribbon cables or you can harm the ports.
  4. Zeepad 7.0 Screen Replacement: passo 4, immagine 1 di 1
    • Cut the power cables connecting between the screen and the motherboard. There should be a red and black cable each.
  5. Zeepad 7.0 Screen Replacement: passo 5, immagine 1 di 2 Zeepad 7.0 Screen Replacement: passo 5, immagine 2 di 2
    • Separate the front screen protector from the lcd screen. There are clamps holding the screen in place.
  6. Zeepad 7.0 Screen Replacement: passo 6, immagine 1 di 3 Zeepad 7.0 Screen Replacement: passo 6, immagine 2 di 3 Zeepad 7.0 Screen Replacement: passo 6, immagine 3 di 3
    • Separate the LCD screen from the metal protecting case with the metal spudger.
  7. Zeepad 7.0 Screen Replacement: passo 7, immagine 1 di 3 Zeepad 7.0 Screen Replacement: passo 7, immagine 2 di 3 Zeepad 7.0 Screen Replacement: passo 7, immagine 3 di 3
    • After creating space to work, warm up a soldering iron.
    • Apply heat onto the solder over the corresponding cut wires to the new screen wires.
    • Come saldare e dissaldare componenti elettrici
    • The soldering iron will be extremely hot. Keep out of direct contact to other wires, the motherboard, and especially the battery.
    • Keep out of reach of children.
Conclusione
To reassemble your device, follow these instructions in order.
Harry Winter
Membro da: 03/26/18
157 Reputazione
1 Guida realizzata
IUPUI, Team S2-G1, Harley Spring 2018 Membro di IUPUI, Team S2-G1, Harley Spring 2018
IUPUI-HARLEY-S18S2G1
3 Membri
4 Guide realizzate
2 Commenti
where do you buy the screen?
Zuzzi Z Amend - Replica
i need a battery an a screen? is their a place on this page where to get them?
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 468
