Salta al contenuto principale
Zebra ZP 450 Power Switch Replacement
Cosa ti serve
  1. Zebra ZP 450 Power Switch Replacement, Motherboard: passo 1, immagine 1 di 1
    • Remove the three 12mm screws from the bottom of the printer using a Phillips #1 screwdriver.
    • Using the TR10 Torx screwdriver, remove the four 8mm screws from the bottom of the device.
  2. Zebra ZP 450 Power Switch Replacement: passo 2, immagine 1 di 1
    • Remove the single 7mm screw located underneath the outfeed using the same Phillips #1 screwdriver.
  3. Zebra ZP 450 Power Switch Replacement: passo 3, immagine 1 di 1
    • Using an opening pick, pry the plastic covering from around the power button and accessory ports.
  4. Zebra ZP 450 Power Switch Replacement: passo 4, immagine 1 di 3 Zebra ZP 450 Power Switch Replacement: passo 4, immagine 2 di 3 Zebra ZP 450 Power Switch Replacement: passo 4, immagine 3 di 3
    • After lifting the plastic casing from the device, use the Phillips #1 screwdriver to remove the single 5mm screw securing the motherboard.
    • Remove all connections to the motherboard.
  5. Zebra ZP 450 Power Switch Replacement, Power Switch: passo 5, immagine 1 di 1
    • Using the soldering iron, unsolder the joints on the back of the motherboard connecting the power switch to the motherboard.
    • For more information on proper soldering technique, please visit the How to Solder and Desolder Connections guide.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 9
Tutti i Tempi: 170
