Introduzione
Use this guide if you need to remove the back panel of your ZTE Whirl 2 (model Z667G). Removing the back panel allows you to access the phone’s motherboard, camera, screen, and speaker. Before using this guide, check the Troubleshooting Page to see if you can find a solution to your phone’s issue.
Cosa ti serve
Power off your phone before removing the battery.
Pry the cover off the back of the phone using your fingers.
Strumento utilizzato in questo passaggio:Tweezers$4.99
Remove four 4 mm screws using a Phillips #00 screwdriver.
Use a tweezers to remove the lock sticker from the bottom right screw. Remove the 4 mm screw using a Phillips #00 screwdriver.
