Salta al contenuto principale
ZTE Lever Loud Speaker Replacement
Cosa ti serve
  1. ZTE Lever Loud Speaker Replacement, Battery: passo 1, immagine 1 di 1
    • Remove the SD card and the Sim card from the device.
    • The Sim and SD cards are not shown here as our device did not come with them.
  2. ZTE Lever Loud Speaker Replacement: passo 2, immagine 1 di 2 ZTE Lever Loud Speaker Replacement: passo 2, immagine 2 di 2
    • Use an iFixit opening tool to separate the back from the device.
  3. ZTE Lever Loud Speaker Replacement: passo 3, immagine 1 di 2 ZTE Lever Loud Speaker Replacement: passo 3, immagine 2 di 2
    • Remove the two 1.6mm Phillips #0 screws from the battery plug cover.
    • Remove the cover.
  4. ZTE Lever Loud Speaker Replacement: passo 4, immagine 1 di 2 ZTE Lever Loud Speaker Replacement: passo 4, immagine 2 di 2
    • Disconnect the battery cable from the motherboard with a plastic opening tool.
  5. ZTE Lever Loud Speaker Replacement: passo 5, immagine 1 di 1
    • Use your hands, or a plastic opening tool, to pry the battery from the phone.
  6. ZTE Lever Loud Speaker Replacement, Volume Buttons: passo 6, immagine 1 di 1
    • Remove the three 1.6mm Phillips #0 screws from the plastic cover on the motherboard.
  7. ZTE Lever Loud Speaker Replacement: passo 7, immagine 1 di 3 ZTE Lever Loud Speaker Replacement: passo 7, immagine 2 di 3 ZTE Lever Loud Speaker Replacement: passo 7, immagine 3 di 3
    • Remove the top plastic motherboard cover using a plastic opening tool.
  8. ZTE Lever Loud Speaker Replacement: passo 8, immagine 1 di 2 ZTE Lever Loud Speaker Replacement: passo 8, immagine 2 di 2
    • Use a plastic opening tool to flip up the retaining flap on the volume ribbon cable ZIF socket.
  9. ZTE Lever Loud Speaker Replacement: passo 9, immagine 1 di 2 ZTE Lever Loud Speaker Replacement: passo 9, immagine 2 di 2
    • Peel up the volume button cable from the phone with hands, or plastic opening tool.
  10. ZTE Lever Loud Speaker Replacement, Power Button: passo 10, immagine 1 di 1
    • Disconnect the power button from the motherboard with a plastic opening tool.
  11. ZTE Lever Loud Speaker Replacement: passo 11, immagine 1 di 2 ZTE Lever Loud Speaker Replacement: passo 11, immagine 2 di 2
    • Peel the power button cable up from the phone with you hands, or a plastic opening tool.
  12. ZTE Lever Loud Speaker Replacement, Motherboard: passo 12, immagine 1 di 2 ZTE Lever Loud Speaker Replacement, Motherboard: passo 12, immagine 2 di 2
    • Remove the seven 1.6mm Phillips #0 screws from the plastic cover on the bottom of the motherboard.
  13. ZTE Lever Loud Speaker Replacement: passo 13, immagine 1 di 1
    • Remove the bottom plastic motherboard cover with your fingers
  14. ZTE Lever Loud Speaker Replacement: passo 14, immagine 1 di 2 ZTE Lever Loud Speaker Replacement: passo 14, immagine 2 di 2
    • Disconnect the camera from the motherboard with a plastic opening tool.
  15. ZTE Lever Loud Speaker Replacement: passo 15, immagine 1 di 1
    • Disconnect the display cable from the motherboard with a plastic opening tool.
  16. ZTE Lever Loud Speaker Replacement: passo 16, immagine 1 di 3 ZTE Lever Loud Speaker Replacement: passo 16, immagine 2 di 3 ZTE Lever Loud Speaker Replacement: passo 16, immagine 3 di 3
  17. ZTE Lever Loud Speaker Replacement: passo 17, immagine 1 di 1
    • Disconnect the rear speaker cable from the motherboard with a plastic opening tool.
  18. ZTE Lever Loud Speaker Replacement: passo 18, immagine 1 di 1
    • Pry the motherboard cell battery from its position on the case of the phone
  19. ZTE Lever Loud Speaker Replacement: passo 19, immagine 1 di 3 ZTE Lever Loud Speaker Replacement: passo 19, immagine 2 di 3 ZTE Lever Loud Speaker Replacement: passo 19, immagine 3 di 3
    • Using the plastic opening tool, pry the motherboard up, sliding along the edge to separate the pieces.
  20. ZTE Lever Loud Speaker Replacement: passo 20, immagine 1 di 1
    • Remove the motherboard with your fingers.
  21. ZTE Lever Loud Speaker Replacement, Loud Speaker: passo 21, immagine 1 di 2 ZTE Lever Loud Speaker Replacement, Loud Speaker: passo 21, immagine 2 di 2
    • Using the plastic opening tool, remove the speaker.
Conclusione
USF Tampa, Team S5-G2, Passmore Spring 2018 Membro di USF Tampa, Team S5-G2, Passmore Spring 2018
USFT-PASSMORE-S18S5G2
3 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 177
