Salta al contenuto principale
ZTE Blade X Max Back Camera Replacement
Cosa ti serve
  1. ZTE Blade X Max Back Camera Replacement, Back Cover: passo 1, immagine 1 di 2 ZTE Blade X Max Back Camera Replacement, Back Cover: passo 1, immagine 2 di 2
    • Use the iOpener or heating pad to heat around the edges of the phone to melt the adhesive.
    • It will take about ten minutes for the adhesive to be heated enough to remove the backing.
    • You will have to reheat the iOpener or heating pad a few times.
  2. ZTE Blade X Max Back Camera Replacement: passo 2, immagine 1 di 3 ZTE Blade X Max Back Camera Replacement: passo 2, immagine 2 di 3 ZTE Blade X Max Back Camera Replacement: passo 2, immagine 3 di 3
    • Slide the Jimmy along the under backing and lightly push the plastic up.
    • You will hear a snapping sound as you slide the Jimmy along the backing. This is from the closures releasing. There should be seven total closures on either side of the device, and three on the top and bottom.
  3. ZTE Blade X Max Back Camera Replacement: passo 3, immagine 1 di 1
    • Carefully remove the backing from the phone once the closures are released.
    • If you do not open all of the closures on the backing do not attempt to pry it off.
    • Be careful when opening the back of the phone. The fingerprint scanner is connected by a thin film that will tear if pulled too roughly.
  4. ZTE Blade X Max Back Camera Replacement: passo 4, immagine 1 di 3 ZTE Blade X Max Back Camera Replacement: passo 4, immagine 2 di 3 ZTE Blade X Max Back Camera Replacement: passo 4, immagine 3 di 3
    • Remove the opaque yellow sticker that indicates where the fingerprint scanner is connected to the back of the device.
  5. ZTE Blade X Max Back Camera Replacement: passo 5, immagine 1 di 3 ZTE Blade X Max Back Camera Replacement: passo 5, immagine 2 di 3 ZTE Blade X Max Back Camera Replacement: passo 5, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    • Remove the two 1mm Phillips #000 screws on the small panel that was underneath the sticker.
    • Use the tweezers to remove the panel.
  6. ZTE Blade X Max Back Camera Replacement: passo 6, immagine 1 di 2 ZTE Blade X Max Back Camera Replacement: passo 6, immagine 2 di 2
    • Use the tweezers to pull at the base of the film to remove the fingerprint scanner.
  7. ZTE Blade X Max Back Camera Replacement, Midframe: passo 7, immagine 1 di 1
    • Remove the SD and SIM cards by pulling out the card tray from the slot on the right side of the device.
  8. ZTE Blade X Max Back Camera Replacement: passo 8, immagine 1 di 3 ZTE Blade X Max Back Camera Replacement: passo 8, immagine 2 di 3 ZTE Blade X Max Back Camera Replacement: passo 8, immagine 3 di 3
    • Remove the sixteen 1mm Phillips #000 screws from the midframe of the phone.
  9. ZTE Blade X Max Back Camera Replacement: passo 9, immagine 1 di 3 ZTE Blade X Max Back Camera Replacement: passo 9, immagine 2 di 3 ZTE Blade X Max Back Camera Replacement: passo 9, immagine 3 di 3
    • Use the Jimmy to remove the midframe from the device.
  10. ZTE Blade X Max Back Camera Replacement, Front Camera: passo 10, immagine 1 di 3 ZTE Blade X Max Back Camera Replacement, Front Camera: passo 10, immagine 2 di 3 ZTE Blade X Max Back Camera Replacement, Front Camera: passo 10, immagine 3 di 3
    • Once the motherboard is exposed, locate the front camera connection in the top right corner of the motherboard.
    • Use the tweezers to remove the front camera.
  11. ZTE Blade X Max Back Camera Replacement, Motherboard: passo 11, immagine 1 di 3 ZTE Blade X Max Back Camera Replacement, Motherboard: passo 11, immagine 2 di 3 ZTE Blade X Max Back Camera Replacement, Motherboard: passo 11, immagine 3 di 3
    • Remove the single 1mm Phillips #000 screw from the motherboard.
    • Detach the five flat connectors.
  12. ZTE Blade X Max Back Camera Replacement: passo 12, immagine 1 di 2 ZTE Blade X Max Back Camera Replacement: passo 12, immagine 2 di 2
    • Use tweezers to remove the protective foam surrounding the headphone jack at the top left of the device.
    • The foam is attached with a thin layer of adhesive which is easy to remove.
  13. ZTE Blade X Max Back Camera Replacement: passo 13, immagine 1 di 3 ZTE Blade X Max Back Camera Replacement: passo 13, immagine 2 di 3 ZTE Blade X Max Back Camera Replacement: passo 13, immagine 3 di 3
    • Use the Jimmy to pry the motherboard out of the phone.
  14. ZTE Blade X Max Back Camera Replacement, Back Camera: passo 14, immagine 1 di 3 ZTE Blade X Max Back Camera Replacement, Back Camera: passo 14, immagine 2 di 3 ZTE Blade X Max Back Camera Replacement, Back Camera: passo 14, immagine 3 di 3
    $3.99
    • Using the angled tweezers, disconnect the rear camera from the motherboard.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 24
Tutti i Tempi: 298
