Salta al contenuto principale
Xtreme Gaming XG-700 Internal Switch Replacement
Cosa ti serve
  1. Xtreme Gaming XG-700 Internal Switch Replacement, Switch: passo 1, immagine 1 di 1
    • Flip the mouse over and peel off the two feet at the bottom of the mouse.
    • Using a Phillips #000 screwdriver, remove the two 5.6 mm screws.
  2. Xtreme Gaming XG-700 Internal Switch Replacement: passo 2, immagine 1 di 1
    • Carefully separate the base of the mouse from the top case as there are ribbon connectors holding the two pieces together.
    • Don't yank or pull the two pieces apart or you will rip the cables.
  3. Xtreme Gaming XG-700 Internal Switch Replacement: passo 3, immagine 1 di 3 Xtreme Gaming XG-700 Internal Switch Replacement: passo 3, immagine 2 di 3 Xtreme Gaming XG-700 Internal Switch Replacement: passo 3, immagine 3 di 3
    • Carefully remove the two cables from their connection point.
    • The top half of the case can be set aside.
  4. Xtreme Gaming XG-700 Internal Switch Replacement: passo 4, immagine 1 di 2 Xtreme Gaming XG-700 Internal Switch Replacement: passo 4, immagine 2 di 2
    • Using a small plastic spudger, release the four clips from each corner of the board.
    • Gently remove the board out of the case.
    • Don't yank or pull the board off the case. There is one cable connecting the board to the case.
  5. Xtreme Gaming XG-700 Internal Switch Replacement: passo 5, immagine 1 di 1
    • Carefully disconnect the ribbon cable from the board.
    • Set aside the case.
  6. Xtreme Gaming XG-700 Internal Switch Replacement: passo 6, immagine 1 di 2 Xtreme Gaming XG-700 Internal Switch Replacement: passo 6, immagine 2 di 2
    • Flip the motherboard over, and using a soldering iron, desolder the three switch prongs on each side of the switch.
    • Remove the broken switch.
Conclusione
Nam Nguyen
Membro da: 06/30/22
154 Reputazione
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 10
Ultimi 7 Giorni: 30
Ultimi 30 Giorni: 86
Tutti i Tempi: 2,057
