Salta al contenuto principale
Xiaomi Mi Pad Motherboard Replacement
Cosa ti serve
  1. Xiaomi Mi Pad Motherboard Replacement, Rear Case Assembly: passo 1, immagine 1 di 1
    • Remove the micro SD card slot from the left side of the device using either the metal pin included with the device or a SIM card eject tool.
  2. Xiaomi Mi Pad Motherboard Replacement: passo 2, immagine 1 di 2 Xiaomi Mi Pad Motherboard Replacement: passo 2, immagine 2 di 2
    • Use a plastic opening tool and/or opening pick to gently pry the back panel away from the device. Work your way around the device, slowly increasing the gap.
    • The back panel has small clips and light adhesive that easily releases from the device.
  3. Xiaomi Mi Pad Motherboard Replacement, Motherboard: passo 3, immagine 1 di 2 Xiaomi Mi Pad Motherboard Replacement, Motherboard: passo 3, immagine 2 di 2
    • Remove the twelve 3 mm Phillips #00 screws on the upper cover of the device.
  4. Xiaomi Mi Pad Motherboard Replacement: passo 4, immagine 1 di 1
    • Remove the upper cover from the device.
  5. Xiaomi Mi Pad Motherboard Replacement: passo 5, immagine 1 di 1
    • Remove the two 3.0 mm Phillips #00 screws securing the motherboard to the device.
  6. Xiaomi Mi Pad Motherboard Replacement: passo 6, immagine 1 di 2 Xiaomi Mi Pad Motherboard Replacement: passo 6, immagine 2 di 2
    • Disconnect the six ribbon cables attached to the motherboard using a plastic opening tool.
  7. Xiaomi Mi Pad Motherboard Replacement: passo 7, immagine 1 di 1
    • Carefully remove the motherboard from the device.
    How to get new one mother board
    MSK DIGITAL MEDIA - Replica
    Pls help me service company saying to me it's motherboard crashed
    I wants new on on low price
    How to get new one of this mi pad mother board
    This is my email sunilhpt90@gmail. com
    Sunil - Replica
Conclusione
Altre 12 persone hanno completato questa guida.
USF Tampa, Team 12-5, Blackwell Fall 2015 Membro di USF Tampa, Team 12-5, Blackwell Fall 2015
USFT-BLACKWELL-F15S12G5
3 Membri
13 Guide realizzate
4 Commenti
It's my email
amaank987321.msk@gmail.com
i'm looking to buy a motherboard for my died mi pad and i couldn't find it any were. Do you know were i can bay one , please help
Vasile Postolache - Replica
I want mi pad mother board
Where I buy
Sunil - Replica
where can i buy matherboard for Xiaomi Mi Pad 4 ?
guyv1975 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 32
Ultimi 30 Giorni: 104
Tutti i Tempi: 7,309
