Salta al contenuto principale
Xelio P900A-BK Battery Replacement
Cosa ti serve
  1. Xelio P900A-BK Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Using a #00 Phillips head screwdriver, remove the two 5.4mm bottom screws.
  2. Xelio P900A-BK Battery Replacement: passo 2, immagine 1 di 2 Xelio P900A-BK Battery Replacement: passo 2, immagine 2 di 2
    • Insert a plastic opening tool between the screen and the rear case and gently work your way around the tablet.
  3. Xelio P900A-BK Battery Replacement: passo 3, immagine 1 di 1
    • Using the plastic opening tool or your fingers, gently pry the pieces of the tablet apart. You will hear the plastic latches pop free.
  4. Xelio P900A-BK Battery Replacement: passo 4, immagine 1 di 3 Xelio P900A-BK Battery Replacement: passo 4, immagine 2 di 3 Xelio P900A-BK Battery Replacement: passo 4, immagine 3 di 3
  5. Xelio P900A-BK Battery Replacement: passo 5, immagine 1 di 2 Xelio P900A-BK Battery Replacement: passo 5, immagine 2 di 2
    • Carefully insert the flat end of a nylon spudger under the battery, and pry the battery up and away from the tablet casing.
    • A small amount of heat may be required to safely remove the battery from the adhesive underneath. Use an iOpener or heat gun to soften the adhesive.
    • Do not bend or puncture the battery.
    • Place the new battery in the same place as the old one, making sure it is oriented the same way as the old one was.
Conclusione
Altre 2 persone hanno completato questa guida.
Marcus Nelson
Membro da: 03/26/15
307 Reputazione
3 Guide realizzate
Un commento
I am attempting to fix one of these for a friend, but I can't seem to get it open! Does it require a significant amount of force? I am afraid I will break it...
skatermonkey06 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 343
