Introduzione
This guide will show you how to access and replace the top motherboard. Soldering is required, so the link to the soldering guide is included to help you.
Slide the battery cover toward the top of the controller to remove it.
Lift up the batteries or the battery pack from the battery compartment.
Turn the device over and remove the directional pad by gently pulling it away from the controller.
Turn the device over and remove the two 70mm torx-6 screws in the bottom left and right corners.
Altre 14 persone hanno completato questa guida.
