Salta al contenuto principale
Xbox One Wireless Controller Model 1708 3.5 mm Audio Port Replacement
Cosa ti serve
  1. Xbox One Wireless Controller Model 1708 3.5 mm Audio Port Replacement, Cover Plate: passo 1, immagine 1 di 2 Xbox One Wireless Controller Model 1708 3.5 mm Audio Port Replacement, Cover Plate: passo 1, immagine 2 di 2
    • Slide the battery cover toward the top of the controller to remove it.
    • Lift up the batteries or the battery pack from the battery compartment.
  2. Xbox One Wireless Controller Model 1708 3.5 mm Audio Port Replacement: passo 2, immagine 1 di 2 Xbox One Wireless Controller Model 1708 3.5 mm Audio Port Replacement: passo 2, immagine 2 di 2
    • Insert a plastic opening tool into the top seam, and gently work the opening tool to the bottom of the controller.
    • Continue using the opening tool to gently pry the side plate off of the controller.
    • Repeat this process for the second side plate.
    Only use a pry tool! The vibration motor wires are exposed and directly accessible from the side when opening. I attempted to open it with a small knife, expecting to be able to gently pry the clips open, accidentally sliced through my right motor’s wires.
    Sawyer Coe - Replica
    Not a sharp of course.
    kajussls121 -
    If you have some Guitar picks laying around they work GREAT!
    Mike Beane - Replica
  3. Xbox One Wireless Controller Model 1708 3.5 mm Audio Port Replacement: passo 3, immagine 1 di 1
    • Gently peel the battery label or punch a hole in the center of the sticker in the battery compartment to reveal the hidden screw.
    • Remove the five 9mm torx-9 security screws from the back of the controller.
    Torx-8 security bits work as well.
    jahiamir - Replica
    Torx 8 or 9 wasn’t working. I used 2.0 minus screwdriver
    richjlee - Replica
    The 2.0 minus worked for me as well.
    metric - Replica
    When sliding in the plastic cover during reassembly be sure it lines up with the battery compartment contacts. It can be really easy to not see it and bend the contacts. If you still encounter force during this step, depressing the triggers out of the way worked for me.
    Drew - Replica
    Since mine is out of warranty I just broke out the security nib with a 2.0 standard bit. Then used a T8 torx.
    Tim LaCrosse - Replica
  4. Xbox One Wireless Controller Model 1708 3.5 mm Audio Port Replacement, Tape Shock Motors in place: passo 4, immagine 1 di 3 Xbox One Wireless Controller Model 1708 3.5 mm Audio Port Replacement, Tape Shock Motors in place: passo 4, immagine 2 di 3 Xbox One Wireless Controller Model 1708 3.5 mm Audio Port Replacement, Tape Shock Motors in place: passo 4, immagine 3 di 3
    • Tape the Rumbler/shock motors in place.
    • This will prevent the motors from falling out.
  5. Xbox One Wireless Controller Model 1708 3.5 mm Audio Port Replacement: passo 5, immagine 1 di 2 Xbox One Wireless Controller Model 1708 3.5 mm Audio Port Replacement: passo 5, immagine 2 di 2
    • Orient the controller so the front plate is facing up.
    • Lift the front cover off of the controller.
  6. Xbox One Wireless Controller Model 1708 3.5 mm Audio Port Replacement: passo 6, immagine 1 di 1
    • Turn the controller face down and gently lift the rear plate.
    • Be careful with the rumble motors, as they tend to fall out, risking damage to the motherboard.
    Reassembly: When placing the back cover on: notice that the battery terminals need to slide inside the cover first. Then compress the triggers slightly, Then the cover will be aligned correctly. Then add the front cover and add screws so it doesn’t come undone.
    hunteil - Replica
    It isn't necessary to take off the back cover
    Otto Hahn - Replica
  7. Xbox One Wireless Controller Model 1708 3.5 mm Audio Port Replacement, Directional Pad: passo 7, immagine 1 di 1
    • Turn the device over and remove the directional pad by gently pulling it away from the controller.
    It needs to be made a little clearer that the thin metal retaining ring needs to be unclipped before pulling on the D-pad. A small, flatbladed screwdriver did it nicely for me.
    Paul Hough - Replica
    As mentioned above, clarification is needed that the metal ring is intended to lay on top of the DPad - you should remove it first when disassembling, and it should be installed after the DPad to hold the DPad down when re-assembling.
    Additionally, the DPad is oriented so that the directional button without an extended tab on the end is on the bottom (down).
    sonofray - Replica
  8. Xbox One Wireless Controller Model 1708 3.5 mm Audio Port Replacement, Joystick Caps: passo 8, immagine 1 di 1
    • Pull the joysticks off of the controller.
    Are the joystick potentiometers soldered to the mother board or just push fit, this guide doesn’t mention soldering so I’m assuming the latter?
    Can you get genuine replacement joystick potentiometers as I’ve only seen cheap eBay type ones?
    Alan - Replica
    The actual joysticks themselves are soldered into the bottom motherboard.
    Bryan Remely -
    So where do i get new parts?
    mrdugi - Replica
  9. Xbox One Wireless Controller Model 1708 3.5 mm Audio Port Replacement, Top Motherboard: passo 9, immagine 1 di 1
    • If the rumble motors fall out of frame, the wires may disconnect from the motherboard . The wires will have to be soldered to reattach the motor.
    • Turn the device over and remove the two 7mm torx-6 screws in the bottom left and right corners.
    What if you don’t care about the rumble motors (always turn that feature off anyway), can I just leave them unattached?
    tracynoelle23 - Replica
  10. Xbox One Wireless Controller Model 1708 3.5 mm Audio Port Replacement, De-soldering required: passo 10, immagine 1 di 3 Xbox One Wireless Controller Model 1708 3.5 mm Audio Port Replacement, De-soldering required: passo 10, immagine 2 di 3 Xbox One Wireless Controller Model 1708 3.5 mm Audio Port Replacement, De-soldering required: passo 10, immagine 3 di 3
    • Firmly grasp the top and bottom motherboards in opposite hands, then gently pull them apart.
    • The top motherboard is still connected to the bottom motherboard. To fully separate the top motherboard, you will need to use a soldering iron.
    • Warning: Do not attempt to disconnect the shielded (gold colored) connector as it is extremely fragile you will break it. It runs between the two boards.
    • De-solder the shielded cable from the lower board instead of attempting to disconnect the connector. De-solder using micro soldering techniquest.
    Soldering is not necessary for separation as on the top motherboard it uses a small connector commonly used in wireless assemblies for antennas. Simply pop it of using any prying tool or just your hand but make sure it is the side that has a gold or brassy finish and not a solder joint.
    Wyatt Faught - Replica
    Hey Wyatt,
    Thanks for the feedback. I was on the team that authored this guide. I did not work on this specific guide so I am not familiar with this specific connector. I will follow up with iFixIt and check this issue. Thanks for the comment!
    Dylan Gross -
    Wyatt is correct that the black wire in the center can be removed from the top motherboard, but it doesn’t do any good to do so as there are two other sets of wires (grey and black twisted pairs leading to the left and right trigger) preventing you from removing the bottom motherboard entirely. These wires are visible in the pictures of this guide.
    Frank Buccella - Replica
    I accidentally broke the part where the black wire connects to. Do I need to buy the top motherboard to fix this problem?
    drakeswifer -
    I can further confirm this as I have just pulled one apart. No soldering iron required.
    Brandon - Replica
    What's is the name of the part for wireless on the controller
    justin edge - Replica
    You'll see..
    kajussls121 -
    In my controller that black cable (the antenna like) was separated form the board is there any way to solder it again (the socket is still conected to plug)
    Dominik Gałczyński - Replica
    I have the same problem. It popped off the board when firm pressure was applied to reconnect the wire after a repair. I'm going to attempt to apply a small bead of solder to the part that popped off, press it in place, and then heat the connector with my iron. But I am not hopeful at all. It's tight, really tight, and if it works it will be through luck alone.
    Michael Broder -
    Any luck? Theres no pad to get the solder to stick to on mine. Im assuming it is the j1 connection. Any idea what this wire is for?
    Matt Gribbin -
    Same issue here. I tried to unplug the antenna connector but the weak solder joints disconnected from the top motherboard instead. Looks like it has couple of bigger solder pads for ground/shielding(?) and one tiny pin in the middle for the actual antenna which can maybe still connect by pushing in place? Looks like a very difficult solder job as everything is so tiny.
    Kari Söderholm -
    Can someone help to find out the actual name of RF connector type?
    mntlzr - Replica
    Hi i destroy black wire connector on top board please help me.
    Mohsen Heidary - Replica
    It’s IPEX 4 connector, i've ordered bunch on chinese site and replaced mine. It was hard but doable.
    mntlzr -
    mntlzr : Thanks a lot for the connector type. More specifically it seems to be IPEX 4 SMD female socket on the top motherboard.
    Kari Söderholm -
    Hi yellow tape on board what
    How does the black wire reconnect? And is it necessary?
    Craig McBeth - Replica
    I just put my controller back together (I opened it just to clean all the buttons since my son spilled some juice on it) and it seems to work wirelessly (with a PC using the dongle that came with the controller) even having broken the small black antenna cable connector off from the top motherboard. Not sure what that cable is used for or is it just an additional antenna for better connectivity. At least my controller still seems to work fine wirelessly without that cable being connected even from several meters away from the computer.
    Kari Söderholm - Replica
    Actually nvm. Now that I tried the controller for a second time on the next day it seems to disconnect all the time so wireless is not working properly. I’ll need to try to fix the antenna cable by soldering. Probably will order a replacement connector (IPEX 4 SMD female socket) and try to solder that on.
    Kari Söderholm -
    I think I broke off a little bit of the black antenna. In the zoomed in shot it showed a tiny little piece of wire soldered on the pad with Z2 above it but mine wasn’t stuck onto it. I see a little white (plastic I think) nub on the end of the wire. My controller’s bluetooth range now is only a foot. What do I do? Do I just replace the cable or can I melt away the plastic material and bridge it with solder?
    Jeremy Clarkson - Replica
    1) TAKE HEED TO THESE WARNINGS AND BE VERY CAREFUL
    2) Instead of separating the boards completely all you need is to get enough space to pull the part out.
    *WHILE HOLDING WITH BOTH HANDS AS IF YOU WHERE PLAYING AND PUSH THE TOP BOARD FORWARD WITH YOUR THUMBS LIKE A DRAWER AND THEN LIFT UP!
    IT WILL SEPARATE JUST ENOUGH TO DO WHAT YOU NEED. *THIS TAKES CARE, FINESSE, & SOME SKILL.
    TyGuy - Replica
    This entire step is asinine. 1: you don't need to completely separate the two boards in order to pull them as a single assembly from the controller. 2: Why the f would you try to get someone to do solder work just to clean up some buttons?
    Jason Chappell - Replica
    Just got done putting mine back together after cleaning("Y" was sticking). I was able to access all screws without completely desoldering, no broken wires. It wasn't even hard to do. As long as you don't try to force anything, it's easy.
    This isn't the first iFixIt guide that has made me go "WTF? You're overcomplicating things!" either. It is a running issue with their guides.
    Jason Chappell -
  11. Xbox One Wireless Controller Model 1708 3.5 mm Audio Port Replacement, 3.5 mm Audio Port: passo 11, immagine 1 di 2 Xbox One Wireless Controller Model 1708 3.5 mm Audio Port Replacement, 3.5 mm Audio Port: passo 11, immagine 2 di 2
    • Remove the audio port from the bottom mother board.
    Can you just leave out the audio port and use the controller or u have to have a replacement to play
    Itachi Uchiha - Replica
    Why would you *need* the audio port? If you are happy to not use then fine, this is an instructional to get it working and by extension a headset one would assume.
    Ali J -
    This piece is just placed in there - sandwiched between the two motherboards. No adhesive, no mechanical attachment, nothing.
    Andrew Sauk - Replica
    So can it be replaced or no? I took it out it dont look fried or anything but it still dont work when reinstalled
    Frank Minelli -
Conclusione
Altre 24 persone hanno completato questa guida.
Dylan Gross
Membro da: 09/25/17
4.686 Reputazione
4 Guide realizzate
Cal Poly, Team S18-G3, Forte Fall 2017 Membro di Cal Poly, Team S18-G3, Forte Fall 2017
CPSU-FORTE-F17S18G3
4 Membri
32 Guide realizzate
6 Commenti
Where do I get a replacement audio port?
cory steers - Replica
Hey Cory,
Sorry, didn’t realize that the part wouldn’t get listed for the guide. I looked around a bit and I would say that it seems the best place to pick these up is ebay.
I found one on there from a reputable seller for $3:
https://www.ebay.com/itm/Repair-Part-3-5...
The seller seems to sell a good amount of these.
Hope that helps!
Dylan Gross -
Anyone know the pin out for this part? I want to just hard wire in a female 3.5mm jack - the way they built this controller is just bad design.
emb - Replica
u can get these on Amazon. i ordered a 3-pack of replacement audio jacks that came with the two security screw drivers and a pry tool. $12 free shipping.
Kaladin - Replica
I removed the 3.5mm jack, cleaned the contacts with a fibre glass contact cleaning brush, and then cleaned both the audio connector and the gold plated PCB pads with IPA, reassembled, and everything worked perfectly. Thanks for the guide, it’s boarder line perfect ;-)
so is the port not soldered onto the board? i have two new controllers my kids purchased that are having issues with the audio port and wonder if the connection is just lose, if it isn’t soldered into place.
Timothy McCormick - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 46
Ultimi 30 Giorni: 173
Tutti i Tempi: 19,873
