Salta al contenuto principale
Xbox One Stereo Headset Microphone Replacement
Cosa ti serve
  1. Xbox One Stereo Headset Microphone Replacement, Microphone: passo 1, immagine 1 di 3 Xbox One Stereo Headset Microphone Replacement, Microphone: passo 1, immagine 2 di 3 Xbox One Stereo Headset Microphone Replacement, Microphone: passo 1, immagine 3 di 3
    • Use the flat end of a spudger to pry out the rubber stopper at the base of the boom.
  2. Xbox One Stereo Headset Microphone Replacement: passo 2, immagine 1 di 1
    • Remove the single 6 mm flathead #2.0 screw exposed after removing the rubber stopper.
  3. Xbox One Stereo Headset Microphone Replacement: passo 3, immagine 1 di 1
    • Lift the joint of the boom up and over its pivot point to separate the microphone from the headset.
  4. Xbox One Stereo Headset Microphone Replacement: passo 4, immagine 1 di 3 Xbox One Stereo Headset Microphone Replacement: passo 4, immagine 2 di 3 Xbox One Stereo Headset Microphone Replacement: passo 4, immagine 3 di 3
    • Using the flat end of the metal spudger, pry the back plate off the boom.
    • The back plate is glued to the boom and must be removed gently.
    • When re-installing, apply a few drops of super glue to hold it in place.
  5. Xbox One Stereo Headset Microphone Replacement: passo 5, immagine 1 di 1
    • Pull the back plate off the boom.
  6. Xbox One Stereo Headset Microphone Replacement: passo 6, immagine 1 di 1
    • Using the flat end of the plastic spudger, gently pry the microphone out of its casing.
    • Desolder the two wires from the back of the microphone. For instructions on how to solder and desolder, please see the soldering technique guide.
    • The white wire connects to the positive node, which is indicated with a "+" on the microphone.
Conclusione
Altre 4 persone hanno completato questa guida.
Trevor Steele
Membro da: 02/01/15
233 Reputazione
Una guida realizzata
Cal Poly, Team 17-37, Amido Winter 2015 Membro di Cal Poly, Team 17-37, Amido Winter 2015
CPSU-AMIDO-W15S17G37
4 Membri
5 guide realizzate
9Commenti sulla guida
Is a replacement microphone available from iFixit?
Scott Minton - Rispondi Condividi
What do you replace the mic with?
Its Me - Rispondi Condividi
They have the microphone for sale
daniel david guerrerogarcia - Rispondi Condividi
Would it presumably be just as easy to replace the microphone speaker with one from another headset, granted it fits ?
harumscxarum - Rispondi Condividi
Any mod to make the cable removable?
kikis.andcream - Rispondi Condividi
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 69
Tutti i Tempi: 24,802
