Introduzione
This guide showcases how the power supply can be replaced in case of a power issue on the Xbox One S All Digital Edition (Model 1681). Symptoms of a faulty power supply may be the Xbox turning on and off randomly or not turning on at all. Note that the entire console will have to be disassembled to properly replace the power supply without damaging other components. Disconnect all cables prior to disassembly.
Cosa ti serve
Position the iFixit Opening Tool's riveted edge in between the top and bottom cover of the plastic enclosure.
Apply downward pressure on the iFixit Opening Tool until the security clip unlocks.
Repeat on different points of the plastic enclosure until the bottom cover is removed.
Remove the two 15mm screws from the front panel using the Torx T8 screwdriver.
Carefully remove the WiFi Card from the metal chassis.
Hello , I have a question.
Can I play the xbox one all digital fully offline, without the wi-fi card plugged into it ?
You should be able to play offline without the card. This is assuming you downloaded whatever games you plan to play before removing the card.
Remove the four 15mm screws attaching the IR Blaster to the metal chassis with the Torx T8 Security screwdriver.
Remove the eight 10mm screws from the bottom of the metal casing using the Torx T9 screwdriver.
Remove the four 15mm screws from the bottom of the heatsink fastener using the Torx T8 screwdriver.
Gently lift the hard drive to free up some space around the power supply.
Altre 4 persone hanno completato questa guida.
3 Commenti
I replaced the power supply and my Xbox still isn't turning on. I used a power supply I got from this website. Please help
Another issue could be the power button on the front power board. If possible, you could try to replace that as well.
