Salta al contenuto principale
Xbox One S All Digital Edition Power Supply Replacement
Cosa ti serve
  1. Xbox One S All Digital Edition Power Supply Replacement, Plastic Enclosure: passo 1, immagine 1 di 3 Xbox One S All Digital Edition Power Supply Replacement, Plastic Enclosure: passo 1, immagine 2 di 3 Xbox One S All Digital Edition Power Supply Replacement, Plastic Enclosure: passo 1, immagine 3 di 3
    • Position the iFixit Opening Tool's riveted edge in between the top and bottom cover of the plastic enclosure.
    • Apply downward pressure on the iFixit Opening Tool until the security clip unlocks.
    • Repeat on different points of the plastic enclosure until the bottom cover is removed.
  2. Xbox One S All Digital Edition Power Supply Replacement: passo 2, immagine 1 di 2 Xbox One S All Digital Edition Power Supply Replacement: passo 2, immagine 2 di 2
    • Remove the six 50 mm green screws (labeled F1-F6) from the metal chassis using a Torx 10 screwdriver.
    • These screws hold the top cover of the plastic enclosure to the chassis.
  3. Xbox One S All Digital Edition Power Supply Replacement: passo 3, immagine 1 di 2 Xbox One S All Digital Edition Power Supply Replacement: passo 3, immagine 2 di 2
    • Apply pressure to peel off the sides of the casing.
    • Separate the metal chassis from the top cover, lifting the back of the chassis up and away from the top cover.
    • The plastic back panel is meant to stay attached to the metal chassis.
  4. Xbox One S All Digital Edition Power Supply Replacement: passo 4, immagine 1 di 1
    • Flip the metal enclosure so that the fan cover is on top.
  5. Xbox One S All Digital Edition Power Supply Replacement, Top Metal Shield: passo 5, immagine 1 di 2 Xbox One S All Digital Edition Power Supply Replacement, Top Metal Shield: passo 5, immagine 2 di 2
    • Remove the two 15mm screws from the front panel using the Torx T8 screwdriver.
  6. Xbox One S All Digital Edition Power Supply Replacement: passo 6, immagine 1 di 3 Xbox One S All Digital Edition Power Supply Replacement: passo 6, immagine 2 di 3 Xbox One S All Digital Edition Power Supply Replacement: passo 6, immagine 3 di 3
    • Carefully slide the top metal case off the frame.
    • This may require shifting the case side to side as you slide up.
  7. Xbox One S All Digital Edition Power Supply Replacement, Wifi Card: passo 7, immagine 1 di 2 Xbox One S All Digital Edition Power Supply Replacement, Wifi Card: passo 7, immagine 2 di 2
    • Remove the three 15 mm screws with the Torx T8 Security Bit Screwdriver.
    • The top of the metal chassis has been removed in the picture, but is not necessary for the replacement.
  8. Xbox One S All Digital Edition Power Supply Replacement: passo 8, immagine 1 di 1
    • Carefully remove the WiFi Card from the metal chassis.
  9. Xbox One S All Digital Edition Power Supply Replacement, IR Blaster: passo 9, immagine 1 di 2 Xbox One S All Digital Edition Power Supply Replacement, IR Blaster: passo 9, immagine 2 di 2
    • Remove the four 15mm screws attaching the IR Blaster to the metal chassis with the Torx T8 Security screwdriver.
  10. Xbox One S All Digital Edition Power Supply Replacement: passo 10, immagine 1 di 2 Xbox One S All Digital Edition Power Supply Replacement: passo 10, immagine 2 di 2
    • Carefully remove the IR Blaster from the metal chassis.
    • The connector is very fragile. Make sure you pull the board away from the case and not sideways.
  11. Xbox One S All Digital Edition Power Supply Replacement, Bottom Metal Shield: passo 11, immagine 1 di 2 Xbox One S All Digital Edition Power Supply Replacement, Bottom Metal Shield: passo 11, immagine 2 di 2
    • Remove the eight 10mm screws from the bottom of the metal casing using the Torx T9 screwdriver.
    • Remove the four 15mm screws from the bottom of the heatsink fastener using the Torx T8 screwdriver.
  12. Xbox One S All Digital Edition Power Supply Replacement: passo 12, immagine 1 di 3 Xbox One S All Digital Edition Power Supply Replacement: passo 12, immagine 2 di 3 Xbox One S All Digital Edition Power Supply Replacement: passo 12, immagine 3 di 3
    • Remove the two plastic pieces from the motherboard.
  13. Xbox One S All Digital Edition Power Supply Replacement: passo 13, immagine 1 di 3 Xbox One S All Digital Edition Power Supply Replacement: passo 13, immagine 2 di 3 Xbox One S All Digital Edition Power Supply Replacement: passo 13, immagine 3 di 3
    • Lift the motherboard up from the metal chassis.
    • The motherboard should easily separate from the metal chassis.
  14. Xbox One S All Digital Edition Power Supply Replacement, Power Supply: passo 14, immagine 1 di 3 Xbox One S All Digital Edition Power Supply Replacement, Power Supply: passo 14, immagine 2 di 3 Xbox One S All Digital Edition Power Supply Replacement, Power Supply: passo 14, immagine 3 di 3
    • Gently lift the hard drive to free up some space around the power supply.
  15. Xbox One S All Digital Edition Power Supply Replacement: passo 15, immagine 1 di 2 Xbox One S All Digital Edition Power Supply Replacement: passo 15, immagine 2 di 2
    • Lift the power supply up and away from the motherboard.
  16. Xbox One S All Digital Edition Power Supply Replacement: passo 16, immagine 1 di 2 Xbox One S All Digital Edition Power Supply Replacement: passo 16, immagine 2 di 2
    • Disconnect the six pin connector from the motherboard.
Conclusione
Altre 8 persone hanno completato questa guida.
Jules Hajjar
Membro da: 10/10/19
1.915 Reputazione
8 Guide realizzate
Cal Poly, Team S12-G6, Regan Fall 2019 Membro di Cal Poly, Team S12-G6, Regan Fall 2019
CPSU-REGAN-F19S12G6
4 Membri
32 Guide realizzate
4Commenti sulla guida
I replaced the power supply and my Xbox still isn't turning on. I used a power supply I got from this website. Please help
William Oliver - Replica
Another issue could be the power button on the front power board. If possible, you could try to replace that as well.
Jules Hajjar -
replace the PSU and still boots up and shuts off
imafuxer - Replica
Completed this process and replaced with a new power supply bought here... Eureka! Fired right back up after re-assembly! Thank you iFixIt... I bought the tool kit and power supply here and everything worked great! I even ended up needing one of the super tiny Torx heads for a clock spring replacement job on my truck, and it was nice to just have it on hand!
Arash E - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 7
Ultimi 7 Giorni: 48
Ultimi 30 Giorni: 211
Tutti i Tempi: 9,928
