Salta al contenuto principale
Xbox One S All Digital Edition Hard Drive Replacement
Cosa ti serve
  1. Xbox One S All Digital Edition Hard Drive Replacement, Plastic Enclosure: passo 1, immagine 1 di 3 Xbox One S All Digital Edition Hard Drive Replacement, Plastic Enclosure: passo 1, immagine 2 di 3 Xbox One S All Digital Edition Hard Drive Replacement, Plastic Enclosure: passo 1, immagine 3 di 3
    • Position the iFixit Opening Tool's riveted edge in between the top and bottom cover of the plastic enclosure.
    • Apply downward pressure on the iFixit Opening Tool until the security clip unlocks.
    • Repeat on different points of the plastic enclosure until the bottom cover is removed.
  2. Xbox One S All Digital Edition Hard Drive Replacement: passo 2, immagine 1 di 2 Xbox One S All Digital Edition Hard Drive Replacement: passo 2, immagine 2 di 2
    • Remove the six 50 mm green screws (labeled F1-F6) from the metal chassis using a Torx 10 screwdriver.
    • These screws hold the top cover of the plastic enclosure to the chassis.
  3. Xbox One S All Digital Edition Hard Drive Replacement: passo 3, immagine 1 di 2 Xbox One S All Digital Edition Hard Drive Replacement: passo 3, immagine 2 di 2
    • Apply pressure to peel off the sides of the casing.
    • Separate the metal chassis from the top cover, lifting the back of the chassis up and away from the top cover.
    • The plastic back panel is meant to stay attached to the metal chassis.
  4. Xbox One S All Digital Edition Hard Drive Replacement: passo 4, immagine 1 di 1
    • Flip the metal enclosure so that the fan cover is on top.
  5. Xbox One S All Digital Edition Hard Drive Replacement, Top Metal Shield: passo 5, immagine 1 di 2 Xbox One S All Digital Edition Hard Drive Replacement, Top Metal Shield: passo 5, immagine 2 di 2
    • Remove the two 15mm screws from the front panel using the Torx T8 screwdriver.
  6. Xbox One S All Digital Edition Hard Drive Replacement: passo 6, immagine 1 di 3 Xbox One S All Digital Edition Hard Drive Replacement: passo 6, immagine 2 di 3 Xbox One S All Digital Edition Hard Drive Replacement: passo 6, immagine 3 di 3
    • Carefully slide the top metal case off the frame.
    • This may require shifting the case side to side as you slide up.
  7. Xbox One S All Digital Edition Hard Drive Replacement, Hard Drive: passo 7, immagine 1 di 2 Xbox One S All Digital Edition Hard Drive Replacement, Hard Drive: passo 7, immagine 2 di 2
    • Remove the two 10mm screws, labeled C3 and C4, attaching the plastic hard drive case to the metal chassis with the Torx T10 Security screwdriver.
  8. Xbox One S All Digital Edition Hard Drive Replacement: passo 8, immagine 1 di 3 Xbox One S All Digital Edition Hard Drive Replacement: passo 8, immagine 2 di 3 Xbox One S All Digital Edition Hard Drive Replacement: passo 8, immagine 3 di 3
    • Lift the hard drive and the black plastic casing from the chassis.
    • Remove the two sets of wires from the motherboard by gently pulling them directly upward.
  9. Xbox One S All Digital Edition Hard Drive Replacement: passo 9, immagine 1 di 2 Xbox One S All Digital Edition Hard Drive Replacement: passo 9, immagine 2 di 2
    • Remove the four 10mm screws attaching the hard drive to the plastic casing with the Torx T8 Security screwdriver.
  10. Xbox One S All Digital Edition Hard Drive Replacement: passo 10, immagine 1 di 1
    • Carefully remove the hard drive from its plastic case.
  11. Xbox One S All Digital Edition Hard Drive Replacement: passo 11, immagine 1 di 2 Xbox One S All Digital Edition Hard Drive Replacement: passo 11, immagine 2 di 2
    • Carefully remove the black wire connection from the hard drive by gently pulling away from the hard drive.
Conclusione
Altre 17 persone hanno completato questa guida.
Jules Hajjar
Membro da: 10/10/19
1.915 Reputazione
8 Guide realizzate
Cal Poly, Team S12-G6, Regan Fall 2019 Membro di Cal Poly, Team S12-G6, Regan Fall 2019
CPSU-REGAN-F19S12G6
4 Membri
32 Guide realizzate
3Commenti sulla guida
Great guide, did though run into problems when using a SSD under 500GB (Kioxia 480GB), seems that the drive must be 500+GB because it did work with Kioxia 960GB. Use the official link for software reinstallation not the broken links in the guide.
Peter H - Replica
Right, how about the hard drive reload?
Alex T - Replica
It's in the conclusion section
John Bagby -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 8
Ultimi 7 Giorni: 52
Ultimi 30 Giorni: 259
Tutti i Tempi: 13,911
