Salta al contenuto principale
X-Treme Tablet Generation 2 Battery Replacement
Cosa ti serve
  1. X-Treme Tablet Generation 2 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Start on the edge of the top corner and use a spudger opening tool to carefully pry the back cover off of the main body.
    • Continue prying around the device, being careful to not dislodge the power button.
  2. X-Treme Tablet Generation 2 Battery Replacement: passo 2, immagine 1 di 3 X-Treme Tablet Generation 2 Battery Replacement: passo 2, immagine 2 di 3 X-Treme Tablet Generation 2 Battery Replacement: passo 2, immagine 3 di 3
    • Pull the cloth tape from the battery to free the body of the battery.
    • Use a solder vacuum and soldering iron to release the red, and then the black, wire from the motherboard.
  3. X-Treme Tablet Generation 2 Battery Replacement: passo 3, immagine 1 di 2 X-Treme Tablet Generation 2 Battery Replacement: passo 3, immagine 2 di 2
    • Remove the battery from the device.
    • Insert the new 3.7 V Li-Polymer battery into the device.
    • Use the soldering iron to solder the red, and then the black, wire back to motherboard.
    • Check out our How to Solder and Desolder Connections guide for help with soldering best practices.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 1,096
