Salta al contenuto principale
X-Street STR Viper Remote Control Motherboard Replacement
Cosa ti serve
  1. X-Street STR Viper Remote Control Motherboard Replacement, Remote Control Motherboard: passo 1, immagine 1 di 1
    • Turn off the remote control. Flip power switch to the off position.
    • Remove the battery from bottom of the remote control for further safety measures.
  2. X-Street STR Viper Remote Control Motherboard Replacement: passo 2, immagine 1 di 1
    • Remove all seven 3mm Phillips #2 screws from the underside panel.
  3. X-Street STR Viper Remote Control Motherboard Replacement: passo 3, immagine 1 di 1
    • Remove five 3mm Phillips #2 screws that connect the motherboard to the back outer shell.
  4. X-Street STR Viper Remote Control Motherboard Replacement: passo 4, immagine 1 di 1
    • Detach the motherboard. Use soldering tools to desolder the red and black wires from the motherboard. To do this, refer to the how to solder/desolder page.
  5. X-Street STR Viper Remote Control Motherboard Replacement: passo 5, immagine 1 di 1
    • Replace the motherboard. Solder the wires back on to the new motherboard using the soldering kit. The black wire should be on the left and the red wire should be on the right.
Conclusione
Cate Kraska
Membro da: 04/01/15
129 Reputazione
1 Guida realizzata
Cal Poly, Team 12-6, Lancaster Spring 2015 Membro di Cal Poly, Team 12-6, Lancaster Spring 2015
CPSU-LANCASTER-S15S12G6
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 10
Tutti i Tempi: 664
