Introduzione
This guide should be straightforward if each step is followed completely and will show you how to successfully replace the motherboard. Be careful with the wires as they can be fragile.
Cosa ti serve
Remove the four 3 mm screws from the bottom panel using a 3 mm Philips #1 screwdriver.
Remove the top body of the car from the bottom. Unplug the light connector. Be careful not to pull any of the wires too hard.
Desolder. Use a solder kit to desolder the wires. Make sure to desolder the wires as close to the motherboard as possible. There are ten wires total to desolder.
Refer to the how to solder/desolder guide for tips.
Un commento
How can I got new motherboard and. New controller becuse I lost my controller
