Salta al contenuto principale
WowWee MiP Robot Power Switch Replacement
Cosa ti serve
  1. WowWee MiP Robot Power Switch Replacement, Battery: passo 1, immagine 1 di 2 WowWee MiP Robot Power Switch Replacement, Battery: passo 1, immagine 2 di 2
    • Remove the three 12.0 mm Phillips # 2 screws from the battery cover.
  2. WowWee MiP Robot Power Switch Replacement: passo 2, immagine 1 di 2 WowWee MiP Robot Power Switch Replacement: passo 2, immagine 2 di 2
    • Carefully pull the battery pack from the robot.
    • Remove the batteries from the battery pack.
  3. WowWee MiP Robot Power Switch Replacement, Wheel: passo 3, immagine 1 di 2 WowWee MiP Robot Power Switch Replacement, Wheel: passo 3, immagine 2 di 2
    • Use a metal spudger to carefully pry off the hubcap without marring the plastic wheel or hubcap.
    • This plastic material is not replaceable. Any damage will be noticeable.
    The hubcap won't come out. It's flat & tight. Even a tiny screwdriver for eyeglass repair can not get under it. Any tricks forgetting it out?
    donna.hester7 - Replica
  4. WowWee MiP Robot Power Switch Replacement: passo 4, immagine 1 di 2 WowWee MiP Robot Power Switch Replacement: passo 4, immagine 2 di 2
    • Remove the 12.0 mm Phillips #2 screw.
    • Hold the wheel in place, or it will rotate as you attempt to remove the screw.
  5. WowWee MiP Robot Power Switch Replacement: passo 5, immagine 1 di 1
    • Pull the wheel off of the square axle.
    • Do not use excessive force while removing the wheel. Pulling too hard on the wheel can damage the axle.
  6. WowWee MiP Robot Power Switch Replacement, WowWee MiP Robot Body Disassembly: passo 6, immagine 1 di 2 WowWee MiP Robot Power Switch Replacement, WowWee MiP Robot Body Disassembly: passo 6, immagine 2 di 2
    • Remove the eight 9.3 mm Phillips #1 screws from the back of the robot.
  7. WowWee MiP Robot Power Switch Replacement: passo 7, immagine 1 di 3 WowWee MiP Robot Power Switch Replacement: passo 7, immagine 2 di 3 WowWee MiP Robot Power Switch Replacement: passo 7, immagine 3 di 3
    • Remove the arms from the body.
    • Carefully open the body compartment.
    • Open the compartment slowly. There are wires connecting the two body pieces together. If pulled too hard, the wires and/or the motherboard could be damaged.
  8. WowWee MiP Robot Power Switch Replacement: passo 8, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Using precision tweezers, disconnect the following three bundles of wires:
    • Connecting the battery pack to the motherboard.
    • Connecting the power switch to the motherboard.
    • Connecting the speaker to the motherboard.
  9. WowWee MiP Robot Power Switch Replacement, Power Switch: passo 9, immagine 1 di 2 WowWee MiP Robot Power Switch Replacement, Power Switch: passo 9, immagine 2 di 2
    • Remove the two 9.3mm Phillips #1 screws.
  10. WowWee MiP Robot Power Switch Replacement: passo 10, immagine 1 di 1
    • Remove the power switch assembly from the body by gently pulling straight out on the wires.
Conclusione
Altre 2 persone hanno completato questa guida.
USF Tampa, Team 3-4, Wollert Spring 2016 Membro di USF Tampa, Team 3-4, Wollert Spring 2016
USFT-WOLLERT-S16S3G4
4 Membri
10 Guide realizzate
1Commento della guida
where can i buy the power switch of MiP
Reinejoe Cacho - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 20
Tutti i Tempi: 674
