Salta al contenuto principale
Womier K66 Mechanical Keyboard Switch Replacement
Cosa ti serve
  1. Womier K66 Mechanical Keyboard Switch Replacement, Switch: passo 1, immagine 1 di 3 Womier K66 Mechanical Keyboard Switch Replacement, Switch: passo 1, immagine 2 di 3 Womier K66 Mechanical Keyboard Switch Replacement, Switch: passo 1, immagine 3 di 3
    • Remove the keycaps from the keyboard using the keycap remover.
  2. Womier K66 Mechanical Keyboard Switch Replacement: passo 2, immagine 1 di 3 Womier K66 Mechanical Keyboard Switch Replacement: passo 2, immagine 2 di 3 Womier K66 Mechanical Keyboard Switch Replacement: passo 2, immagine 3 di 3
    • Flip the keyboard over so the backside is facing up.
    • Use the Phillips #0 screwdriver to remove the fourteen 1.52 mm screws.
    • Remove the back plate of the keyboard.
  3. Womier K66 Mechanical Keyboard Switch Replacement: passo 3, immagine 1 di 3 Womier K66 Mechanical Keyboard Switch Replacement: passo 3, immagine 2 di 3 Womier K66 Mechanical Keyboard Switch Replacement: passo 3, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Desoldering Pump
    $3.99
    Compra
    • If you're unfamiliar with solder or need a refresher, review the How to Solder and Desolder guide.
    • Set your soldering iron to 400 °C.
    • Apply the soldering iron to the solder joints and remove the solder with the desoldering pump.
    • Be careful when soldering as the iron is very hot.
  4. Womier K66 Mechanical Keyboard Switch Replacement: passo 4, immagine 1 di 3 Womier K66 Mechanical Keyboard Switch Replacement: passo 4, immagine 2 di 3 Womier K66 Mechanical Keyboard Switch Replacement: passo 4, immagine 3 di 3
    • Remove the key switch from the board using the key switch puller.
  5. Womier K66 Mechanical Keyboard Switch Replacement: passo 5, immagine 1 di 3 Womier K66 Mechanical Keyboard Switch Replacement: passo 5, immagine 2 di 3 Womier K66 Mechanical Keyboard Switch Replacement: passo 5, immagine 3 di 3
    • Place your new switch onto the board.
    • In this case we used a Gateron Linear switch but this could be any variety of switches.
  6. Womier K66 Mechanical Keyboard Switch Replacement: passo 6, immagine 1 di 3 Womier K66 Mechanical Keyboard Switch Replacement: passo 6, immagine 2 di 3 Womier K66 Mechanical Keyboard Switch Replacement: passo 6, immagine 3 di 3
    • Apply new solder to the soldering joints of the replacement switch.
Conclusione
Minh-Tam Nguyen
Membro da: 11/03/22
133 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 12
Tutti i Tempi: 448
