Introduzione
This guide will help you to replace the speakers if you are experiencing audio issues.
Place Gamepad face down and remove the two 4.7 mm screws with a Phillips size #00 screwdriver.
Remove 10 9mm screws with Tri-Wing size Y1 screwdriver around the outer case.
Lift up on the back of case.
Altre 4 persone hanno completato questa guida.
