Introduzione
Use this guide to replace the main board a.k.a. Cycle Control Unit (CCU) on your Whirlpool WED87HED Dryer.
The main board is the "brain" of the dryer. When it fails, the dryer will operate erratically or not operate at all.
Cosa ti serve
Attrezzo utilizzato in questo passaggio:FixMat$36.95
Use a 5/16 inch nut driver to remove the two 15.7 mm-long screws securing the top panel to the rear panel bracket.
Grasp the top and slide it 1/2 to 1 inch toward the rear of the machine.
Using a flat head screwdriver or a spudger, release the cover clips.
Attrezzo utilizzato in questo passaggio:Anti-Static Wrist Strap$7.95
Lift the board with one hand and use the other to release each clip with a spudger.
Repair didn’t go as planned? Ask our Answers community for help.
