Salta al contenuto principale
Whirlpool Refrigerator Water Filter Housing Replacement
Cosa ti serve
  1. Whirlpool Refrigerator Water Filter Housing Replacement, Safety precautions: passo 1, immagine 1 di 1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. Whirlpool Refrigerator Water Filter Housing Replacement, Open the doors: passo 2, immagine 1 di 3 Whirlpool Refrigerator Water Filter Housing Replacement, Open the doors: passo 2, immagine 2 di 3 Whirlpool Refrigerator Water Filter Housing Replacement, Open the doors: passo 2, immagine 3 di 3
    • Depending on your repair, open one or both doors.
  3. Whirlpool Refrigerator Water Filter Housing Replacement, Unfasten the front panel: passo 3, immagine 1 di 3 Whirlpool Refrigerator Water Filter Housing Replacement, Unfasten the front panel: passo 3, immagine 2 di 3 Whirlpool Refrigerator Water Filter Housing Replacement, Unfasten the front panel: passo 3, immagine 3 di 3
    • Remove the screw(s) securing the front panel.
  4. Whirlpool Refrigerator Water Filter Housing Replacement, Remove the front panel: passo 4, immagine 1 di 3 Whirlpool Refrigerator Water Filter Housing Replacement, Remove the front panel: passo 4, immagine 2 di 3 Whirlpool Refrigerator Water Filter Housing Replacement, Remove the front panel: passo 4, immagine 3 di 3
    • Pull the front panel straight off the chassis and remove it.
    • You may have to slightly open the water filter door to remove the front panel completely.
  5. Whirlpool Refrigerator Water Filter Housing Replacement, Unfasten the water filter housing: passo 5, immagine 1 di 1
    • Remove the screw(s) securing the water filter housing.
    • Remove the screw(s) securing the wire harness grounding wire.
  6. Whirlpool Refrigerator Water Filter Housing Replacement, Reposition the housing: passo 6, immagine 1 di 2 Whirlpool Refrigerator Water Filter Housing Replacement, Reposition the housing: passo 6, immagine 2 di 2
    • Pull the housing out of the chassis enough to access its left-hand water connections.
  7. Whirlpool Refrigerator Water Filter Housing Replacement, Remove the clips: passo 7, immagine 1 di 3 Whirlpool Refrigerator Water Filter Housing Replacement, Remove the clips: passo 7, immagine 2 di 3 Whirlpool Refrigerator Water Filter Housing Replacement, Remove the clips: passo 7, immagine 3 di 3
    • Place a clean and dry rag under the water hoses.
    • Use needle nose pliers, or your fingers, to remove any clips on the top and bottom water hose.
  8. Whirlpool Refrigerator Water Filter Housing Replacement, Disconnect the water hoses: passo 8, immagine 1 di 1
    • Compress the plastic ring near the end of the water hose.
    • While compressing the ring, pull the hose away from the ring to disconnect it.
    • Repeat for the other water hose.
  9. Whirlpool Refrigerator Water Filter Housing Replacement, Remove the housing: passo 9, immagine 1 di 1
    • Remove the water filter housing.
Conclusione
Repair didn’t go as planned? Ask our Answers community for help.
nicO
Membro da: 04/14/15
15.876 Reputazione
88 Guide realizzate
Global Fixers Membro di Global Fixers
Community
29 Membri
465 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 24
Ultimi 30 Giorni: 88
Tutti i Tempi: 1,051
