Salta al contenuto principale
Whirlpool Refrigerator Icemaker Assembly Replacement
Cosa ti serve
  1. Whirlpool Refrigerator Icemaker Assembly Replacement, Safety precautions: passo 1, immagine 1 di 1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. Whirlpool Refrigerator Icemaker Assembly Replacement, Open the doors: passo 2, immagine 1 di 3 Whirlpool Refrigerator Icemaker Assembly Replacement, Open the doors: passo 2, immagine 2 di 3 Whirlpool Refrigerator Icemaker Assembly Replacement, Open the doors: passo 2, immagine 3 di 3
    • Depending on your repair, open one or both doors.
  3. Whirlpool Refrigerator Icemaker Assembly Replacement, Remove the icemaker tray: passo 3, immagine 1 di 2 Whirlpool Refrigerator Icemaker Assembly Replacement, Remove the icemaker tray: passo 3, immagine 2 di 2
    • Pull the icemaker tray completely out of its slot in the chassis.
  4. Whirlpool Refrigerator Icemaker Assembly Replacement, Unfasten the icemaker assembly: passo 4, immagine 1 di 2 Whirlpool Refrigerator Icemaker Assembly Replacement, Unfasten the icemaker assembly: passo 4, immagine 2 di 2
    • Remove the screw(s) securing the icemaker assembly.
    • The second photo shows the potential screw locations in a removed icemaker assembly.
  5. Whirlpool Refrigerator Icemaker Assembly Replacement, Reposition the icemaker assembly: passo 5, immagine 1 di 3 Whirlpool Refrigerator Icemaker Assembly Replacement, Reposition the icemaker assembly: passo 5, immagine 2 di 3 Whirlpool Refrigerator Icemaker Assembly Replacement, Reposition the icemaker assembly: passo 5, immagine 3 di 3
    • Pull the icemaker assembly off its slot in the chassis.
    • Let the assembly hang to access its connectors.
  6. Whirlpool Refrigerator Icemaker Assembly Replacement, Disconnect the icemaker assembly: passo 6, immagine 1 di 3 Whirlpool Refrigerator Icemaker Assembly Replacement, Disconnect the icemaker assembly: passo 6, immagine 2 di 3 Whirlpool Refrigerator Icemaker Assembly Replacement, Disconnect the icemaker assembly: passo 6, immagine 3 di 3
    • Disconnect any connectors attached to the icemaker assembly.
  7. Whirlpool Refrigerator Icemaker Assembly Replacement, Remove the icemaker assembly: passo 7, immagine 1 di 1
    • Remove the icemaker assembly.
Conclusione
Repair didn’t go as planned? Ask our Answers community for help.
nicO
Membro da: 04/14/15
15.876 Reputazione
88 Guide realizzate
Global Fixers Membro di Global Fixers
Community
29 Membri
466 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 8
Ultimi 7 Giorni: 38
Ultimi 30 Giorni: 150
Tutti i Tempi: 1,614
