Salta al contenuto principale
Whirlpool Refrigerator Door Light Replacement
Cosa ti serve
  1. Whirlpool Refrigerator Door Light Replacement, Open the doors: passo 1, immagine 1 di 3 Whirlpool Refrigerator Door Light Replacement, Open the doors: passo 1, immagine 2 di 3 Whirlpool Refrigerator Door Light Replacement, Open the doors: passo 1, immagine 3 di 3
    • Depending on your repair, open one or both doors.
  2. Whirlpool Refrigerator Door Light Replacement, Unclip the door light: passo 2, immagine 1 di 2 Whirlpool Refrigerator Door Light Replacement, Unclip the door light: passo 2, immagine 2 di 2
    • Be careful during this step, as it's easy to scratch the interior of the fridge or crack cold and brittle plastic.
    • Carefully insert a flathead screwdriver, or a similar tool, between the door light and the chassis.
    • Pry up to separate the door light enough so you can grip it with your fingers.
  3. Whirlpool Refrigerator Door Light Replacement: passo 3, immagine 1 di 3 Whirlpool Refrigerator Door Light Replacement: passo 3, immagine 2 di 3 Whirlpool Refrigerator Door Light Replacement: passo 3, immagine 3 di 3
    • Tilt the door light downward to completely release its plastic clips.
    • Pull the light down to expose its connectors.
  4. Whirlpool Refrigerator Door Light Replacement: passo 4, immagine 1 di 3 Whirlpool Refrigerator Door Light Replacement: passo 4, immagine 2 di 3 Whirlpool Refrigerator Door Light Replacement: passo 4, immagine 3 di 3
    • Disconnect any connectors attached to the door light.
    • Remove the door light.
Conclusione
Repair didn’t go as planned? Ask our Answers community for help.
nicO
Membro da: 04/14/15
15.876 Reputazione
88 Guide realizzate
Global Fixers Membro di Global Fixers
Community
29 Membri
466 Guide realizzate
Un commento
Hello Gents,
I have a Kitchen aid fridge Model # KRFF300ESS01 and one of the top Led light is flickering they come as a set module # W10897058, and connected by interconnecting wiring, (concealed in the panel) can any one please help me as to how I can change them out.....the other light is good and there is a screw which holds up the plastic panel housing the lights, can I get them out by removing the panel or do I get them out by taking them out one at a time and how do I get the wiring in like that .....cant post any pictures but will appreciate any feed back,
ashley demonte - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 9
Ultimi 7 Giorni: 68
Ultimi 30 Giorni: 312
Tutti i Tempi: 10,179
