Salta al contenuto principale
Whirlpool Dryer Main Board Replacement
Cosa ti serve
  1. Whirlpool Dryer Main Board Replacement, Safety Precautions: passo 1, immagine 1 di 1
    • Before you begin your repair, unplug your dryer.
    • Your power cord may have four prongs rather than three. The additional prong is a ground connection.
  2. Whirlpool Dryer Main Board Replacement, Unfasten the top panel: passo 2, immagine 1 di 3 Whirlpool Dryer Main Board Replacement, Unfasten the top panel: passo 2, immagine 2 di 3 Whirlpool Dryer Main Board Replacement, Unfasten the top panel: passo 2, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    FixMat
    $36.95
    Compra
    • Throughout this guide, keep track of each screw and reinstall it exactly where it came from.
    • Use a nut driver to remove the screws securing the top panel to the rear panel bracket.
  3. Whirlpool Dryer Main Board Replacement, Remove the top panel: passo 3, immagine 1 di 2 Whirlpool Dryer Main Board Replacement, Remove the top panel: passo 3, immagine 2 di 2
    • Grasp the top and slide it 1/2 to 1 inch toward the rear of the machine.
  4. Whirlpool Dryer Main Board Replacement: passo 4, immagine 1 di 2 Whirlpool Dryer Main Board Replacement: passo 4, immagine 2 di 2
    • Lift the top panel upward to separate it from the chassis.
    • Remove the top panel from the machine.
  5. Whirlpool Dryer Main Board Replacement, Disconnect the Main Board: passo 5, immagine 1 di 2 Whirlpool Dryer Main Board Replacement, Disconnect the Main Board: passo 5, immagine 2 di 2
    • Disconnect all the wires from the main board.
  6. Whirlpool Dryer Main Board Replacement: passo 6, immagine 1 di 3 Whirlpool Dryer Main Board Replacement: passo 6, immagine 2 di 3 Whirlpool Dryer Main Board Replacement: passo 6, immagine 3 di 3
    • Continue disconnecting the main board.
  7. Whirlpool Dryer Main Board Replacement: passo 7, immagine 1 di 3 Whirlpool Dryer Main Board Replacement: passo 7, immagine 2 di 3 Whirlpool Dryer Main Board Replacement: passo 7, immagine 3 di 3
    • Finish disconnecting the wires from the main board.
  8. Whirlpool Dryer Main Board Replacement, Unfasten the main board cover: passo 8, immagine 1 di 3 Whirlpool Dryer Main Board Replacement, Unfasten the main board cover: passo 8, immagine 2 di 3 Whirlpool Dryer Main Board Replacement, Unfasten the main board cover: passo 8, immagine 3 di 3
    • Using a flat head screwdriver or a spudger, release the cover clips.
  9. Whirlpool Dryer Main Board Replacement, Remove the main board cover: passo 9, immagine 1 di 3 Whirlpool Dryer Main Board Replacement, Remove the main board cover: passo 9, immagine 2 di 3 Whirlpool Dryer Main Board Replacement, Remove the main board cover: passo 9, immagine 3 di 3
    • Lift the cover to release the tabs on the opposite side of the main board housing.
    • Remove the cover.
  10. Whirlpool Dryer Main Board Replacement, Release the main board: passo 10, immagine 1 di 3 Whirlpool Dryer Main Board Replacement, Release the main board: passo 10, immagine 2 di 3 Whirlpool Dryer Main Board Replacement, Release the main board: passo 10, immagine 3 di 3
    Anti-Static Wrist Strap
    $7.95
    Compra
    • There are six retaining clips securing the main board. Start at one end and work towards the other.
    • When you're handling the main board, wear an anti-static strap if possible, or regularly touch the exposed metal parts of the dryer to prevent electrostatic damage to the board.
    • Lift the board with one hand and use the other to release each clip with a spudger.
    • As you go, keep a gentle upward pull on the board so that the released clips don't snap back into place as you work.
    • Alternate sides of the board when releasing the clips.
  11. Whirlpool Dryer Main Board Replacement: passo 11, immagine 1 di 2 Whirlpool Dryer Main Board Replacement: passo 11, immagine 2 di 2
    • Release the remaining clips until the board is completely separated from its housing.
  12. Whirlpool Dryer Main Board Replacement, Remove the main board: passo 12, immagine 1 di 1
    • Remove the main board from its housing.
Conclusione
Repair didn’t go as planned? Ask our Answers community for help.
Bill Gilbert
Membro da: 06/30/22
30.797 Reputazione
213 Guide realizzate
iFixit Membro di iFixit
Staff
140 Membri
18.077 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 12
Tutti i Tempi: 135
