Salta al contenuto principale
Weinmann VENTImotion and VENTIlogic Control Board Replacement
Attrezzature medicali
Né iFixit né questa guida di riparazione sono approvati dal produttore del dispositivo medicale o affiliati ad esso.
Cosa ti serve
  1. Weinmann VENTImotion and VENTIlogic Control Board Replacement, Control Board: passo 1, immagine 1 di 1
    • Open the device
    • 1) Place the device on a non-slip surface with the top facing downwards.
    • 2) Remove the filter cassette from the top part of the housing.
    • 3) Undo and remove the 6 screws (34)
  2. Weinmann VENTImotion and VENTIlogic Control Board Replacement: passo 3, immagine 1 di 1
    • Disconnect the following
    • - encoder connector (82)
    • -connectors of interfaces (84) and (85) of the control board.
  3. Weinmann VENTImotion and VENTIlogic Control Board Replacement: passo 4, immagine 1 di 1
    • Disconnect the ribbon cable of the display and the fascia film:
    • Pull the latch out until you feel resistance. You can then pull out the ribbon cable.
    • If the latch has not been opened correctly, the ribbon cable may be damaged when it is pulled out.
  4. Weinmann VENTImotion and VENTIlogic Control Board Replacement: passo 5, immagine 1 di 1
    • Pull flow measurement hoses (56) off the flow sensor.
  5. Weinmann VENTImotion and VENTIlogic Control Board Replacement: passo 6, immagine 1 di 1
    • Pull pressure measurement hoses (57) off the pressure sensors.
  6. Weinmann VENTImotion and VENTIlogic Control Board Replacement: passo 7, immagine 1 di 1
    • Insert a new battery (52) in the appropriate holder of the new control board
    • Screw on spring (54)
  7. Weinmann VENTImotion and VENTIlogic Control Board Replacement: passo 8, immagine 1 di 1
    • Put the control board in the top part of the housing and attach it with the four screws (51)
  8. Weinmann VENTImotion and VENTIlogic Control Board Replacement: passo 9, immagine 1 di 1
    • Reattach the pressure measurement hoses (57) to the pressure sensors.
    • Connect the flow sensor marked Hi to the hose connector marked Hi at the device outlet.
  9. Weinmann VENTImotion and VENTIlogic Control Board Replacement: passo 10, immagine 1 di 1
    • Attach the flow measurement hoses (56) to the flow sensor
    • Connect the connection of the flow sensor marked Lo to the hose connector marked Lo at the device outlet.
  10. Weinmann VENTImotion and VENTIlogic Control Board Replacement: passo 11, immagine 1 di 1
    • To prevent the hoses from kinking, position flow measurement hoses (56) and pressure measurement hoses (57) as shown.
  11. Weinmann VENTImotion and VENTIlogic Control Board Replacement: passo 12, immagine 1 di 1
    • Connect the ribbon cable for the fascia film and the display to the control board again:
    • –pull the latch upwards.
    • –push the ribbon cable into the connector.
    • –press the latch back down
  12. Weinmann VENTImotion and VENTIlogic Control Board Replacement: passo 13, immagine 1 di 1
    • Plug the connectors of the interfaces and the rotary knob into the appropriate slots of the control board.
  13. Weinmann VENTImotion and VENTIlogic Control Board Replacement: passo 14, immagine 1 di 2 Weinmann VENTImotion and VENTIlogic Control Board Replacement: passo 14, immagine 2 di 2
    • Refit the box and filter holder.
    • Connect the box and the filter holder to one another by reconnecting the intake side hose (73) from both parts.
    • Refit box (58) and filter holder (37) back on the top part of the housing together.
    • Connect the pressure-side hose (74) from the box.
  14. Weinmann VENTImotion and VENTIlogic Control Board Replacement: passo 16, immagine 1 di 2 Weinmann VENTImotion and VENTIlogic Control Board Replacement: passo 16, immagine 2 di 2
    • Close the Device: Hold the bottom part of the housing (35) up to the side of the top part of the housing (36)
    • Plug the connecting cables for the humidifier (42) and the alarm (43) onto the relevant connectors.
    • Check that all hoses and cables are plugged on firmly.
    • Place the bottom part of the housing (35) on the top part of the housing (36). Ensure that no cables or hoses are trapped or bent.
    • Now screw the top part of the housing tight using the 6 screws (34).
    • Then turn the device back over
    • Check contrast and adjust if necessary .
    • Reset the date and time.
    • Set the date as follows: Year, Month, Day
Conclusione
Jay Vidinoff
Membro da: 04/07/20
610 Reputazione
2 Guide realizzate
Cal Poly, Team S7-G19, Paton Spring 2020 Membro di Cal Poly, Team S7-G19, Paton Spring 2020
CPSU-PATON-S20S7G19
3 Membri
4 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 11
Tutti i Tempi: 245
