Salta al contenuto principale
Weinmann VENTImotion and VENTIlogic Power Board Replacement
Attrezzature medicali
Né iFixit né questa guida di riparazione sono approvati dal produttore del dispositivo medicale o affiliati ad esso.
  1. Weinmann VENTImotion and VENTIlogic Power Board Replacement, Power Board: passo 1, immagine 1 di 2 Weinmann VENTImotion and VENTIlogic Power Board Replacement, Power Board: passo 1, immagine 2 di 2
    • Open the Device by following these steps:
    • Open the device only with the power supply plug disconnected.
    • Place the device on a non-slip surface with the top facing downwards.
    • Remove the filter cassette from the top part of the housing
    • Undo and remove the 6 screws (34)
    • Open the bottom part of the housing (35) away to the side.
    • Undo the connecting cables for the humidifier (42) and the alarm (43)
    • You can now put the bottom part of the housing (35) to one side.
  2. Weinmann VENTImotion and VENTIlogic Power Board Replacement: passo 2, immagine 1 di 1
    • Disconnect the power board connecting cable (45) from the power board (41).
  3. Weinmann VENTImotion and VENTIlogic Power Board Replacement: passo 3, immagine 1 di 1
    • Disconnect the Motor Cable
  4. Weinmann VENTImotion and VENTIlogic Power Board Replacement: passo 4, immagine 1 di 1
    • Disconnect the O2 valve/power board connecting cable (70) from the power board.
    • Disconnect all connecting cables from the control board.
    • Remove the power board from the top part of the housing.
  5. Weinmann VENTImotion and VENTIlogic Power Board Replacement: passo 7, immagine 1 di 1
    • Take the rechargeable battery connecting cable (48) out of the groove and disconnect it from the power board (41).
  6. Weinmann VENTImotion and VENTIlogic Power Board Replacement: passo 8, immagine 1 di 1
    • Disconnect the cables of the old power board and plug them into the appropriate slots of the new power board 41:
    • –power board/control board connecting cable (46)
    • –rechargeable battery connecting cable (48)
    • –earth cable (47)
  7. Weinmann VENTImotion and VENTIlogic Power Board Replacement: passo 9, immagine 1 di 2 Weinmann VENTImotion and VENTIlogic Power Board Replacement: passo 9, immagine 2 di 2
    • Connect the power board/mains supply unit connecting cable (45) to the new power board.
    • Position the new power board in the top part of the housing.
  8. Weinmann VENTImotion and VENTIlogic Power Board Replacement: passo 11, immagine 1 di 1
    • Restore the connections to the control board.
Conclusione
Emily Jacobson
Membro da: 04/06/20
288 Reputazione
1 Guida realizzata
Cal Poly, Team S7-G19, Paton Spring 2020 Membro di Cal Poly, Team S7-G19, Paton Spring 2020
CPSU-PATON-S20S7G19
3 Membri
4 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 11
Tutti i Tempi: 215
