Introduzione
Use this guide to replace the mechanical seal kit behind the impeller on a Wacker PG1 (2014) Pump.
Cosa ti serve
Before beginning repairs, disconnect and remove all hoses.
Flip the motor ignition switch into the OFF position.
Use a 13 mm socket to remove the two bolts securing the handle.
Use a 4 mm hex key to remove the bolt securing the engine cover.
Insert a flathead screwdriver between two fan blades on the motor fan assembly.
Tap the impeller on one of its blades with a rubber mallet and a punch to break it loose from the threads on the output shaft.
Remove the seal kit washer.
Remove the seal kit flange.
Remove the seal kit bushing.
